Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
06-09-2005, 09:46 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.thefonedoc.com Age: 55
Member: 84155 Status: Offline Thanks Meter: 8 | DO NOT connect phone battery to connector. Use SmartClip power only. Also, if possible, try powering your smartclip using an external power supply instead of a battery. Once you connect the connector on to the phone, and power on your clip, before you try unlocking, just try to power on your sendo. If it is powering on, your connection is OK. Now the unlock procedure. Phone Off Connect the connector Power on the clip. Press the unlock button and IMMEDIATELY press the power button on the Sendo..... any longer than half a second or so and it will not work. Please post back results |
08-24-2005, 23:19 | #6 (permalink) |
No Life Poster Join Date: Apr 2003
Member: 25806 Status: Offline Sonork: 100.78148 Thanks Meter: 2,915 | @doomstyle Please check Mobile IMEI if they show ?????????? so u Rebuild this in Delok or Multibox. caz smartclip not work if sendo mobile have ????? imei br tahir |
How to unlock sendo m570? | mobile_2003 | Various | 17 | 09-25-2013 16:19 |
How to unlock Sendo S200 and S330. | E&D | Various | 8 | 11-21-2004 21:23 |
How to unlock Sendo X | luskao | Various | 8 | 10-30-2004 00:54 |
how to unlock sendo s330 | george gsm | Various | 16 | 10-21-2004 21:55 |
how to unlock sendo s200 | eureka8888 | Various | 0 | 11-03-2001 14:13 |
