Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
03-15-2004, 22:47 | #4 (permalink) |
Freak Poster Join Date: Oct 2003 Location: kelaa m'gouna -ouarzazate-Moro Age: 42
Member: 41449 Status: Offline Thanks Meter: 4 | her's what i found in this forum, Maxon Epsipon SG-1000 for Sewon and TLC Firmware Downloader: -- First connect the module and the terminal using the right data cable (RS232 compatible) - TX : Transmit Data - RX : Receive Data - GND : ground -- It is also strongly recommended to use the following signal: - RTS : Request To send - CTS : Clear To Send -- Use "HyperTerminal" from Windows -- Check the baudrate : "AT+IPR?" -- Configure the speed of the module at the highest baudrate (115200, by default the WISMO is configured at 9600bps) -- Increase the baudrate (115200bps) in case it has not be done before: "AT+IPR=115200" -- Check the software version: "ATI3" ( or AT+CGMR) gives the software version -- AT+WDWL? gives the downloader version -- Send the files using XModem protocol. -- Send the AT command "AT+WDWL" to switch the WISMO on download mode. -- The module sends "+WDWL : 0" : to inform that it turns in download mode. -- When there is no more file to be downloaded, the user exits the download mode by sending the AT command "AT+CFUN=1" (Reset the WISMO module) -- At the end of the download, execute an AT+CFUN=1 (or hard reset). |
04-23-2004, 14:12 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Planet earth
Member: 5169 Status: Offline Thanks Meter: 684 | KEYBOARD UP ______________ |""""""""""""""""""" | 1.................18 gnd-pins 18/8/15 VCC-pin 17 i need only tx and rx pinout can someone send me this thankS DUSK Last edited by DUSKnenixs; 04-23-2004 at 15:10. |
04-23-2004, 18:46 | #7 (permalink) |
Insane Poster Join Date: Apr 2000
Member: 1303 Status: Offline Thanks Meter: 2 | KEYBOARD UP _____________ |""""""""""""""""""" | 1.................18 8 = GND 9 = TX 12 = RX --------------------------------------------------------- Full Pinout MAXON Epsilon (SG-1000) made by SEWON and BIRD S1000, TCL 999D 1 - VBATT 2 - GPIO_SCL 3 - GPIO_SDA 4 - NC 5 - SIKIP_EXT 6 - MICIN_EXT 7 - MICIP_EXT 8 - GND 9 - TXD 10 - CTS 11 - DTR 12 - RXD 13 - RTS 14 - BOOT 15 - GND 16 - CHARGER_IN 17 - CHARGER_IN 18 - GND Connector Sweon SG1000/1100 (18 pins) |
04-24-2004, 13:43 | #10 (permalink) |
Member: 5169 Status: Offline Thanks Meter: 684 | i try to do this: -- First connect the module and the terminal using the right data cable (RS232 compatible) - TX : Transmit Data - RX : Receive Data - GND : ground -- It is also strongly recommended to use the following signal: - RTS : Request To send - CTS : Clear To Send -- Use "HyperTerminal" from Windows -- Check the baudrate : "AT+IPR?" -- Configure the speed of the module at the highest baudrate (115200, by default the WISMO is configured at 9600bps) -- Increase the baudrate (115200bps) in case it has not be done before: "AT+IPR=115200" -- Check the software version: "ATI3" ( or AT+CGMR) gives the software version -- AT+WDWL? gives the downloader version -- Send the files using XModem protocol. -- Send the AT command "AT+WDWL" to switch the WISMO on download mode. -- The module sends "+WDWL : 0" : to inform that it turns in download mode. -- When there is no more file to be downloaded, the user exits the download mode by sending the AT command "AT+CFUN=1" (Reset the WISMO module) -- At the end of the download, execute an AT+CFUN=1 (or hard reset). and not working for me can ou please sas help me? thansk |
Please help unlock my Maxon epsilon | gigi200 | Phone Unlocking Codes & Maps | 4 | 02-22-2004 18:51 |
I need pinout maxon epsilon | Julietta_13 | Various | 0 | 12-03-2003 18:34 |
Please one code for Maxon Epsilon | questman | Phone Unlocking Codes & Maps | 30 | 09-28-2003 22:43 |
please help me with maxon epsilon-1000 code. | crossings | Phone Unlocking Codes & Maps | 3 | 09-17-2003 08:39 |
