Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
05-24-2000, 01:33 | #1 (permalink) |
Insane Poster Join Date: Mar 2000 Location: Deep Space 9 Age: 47
Member: 1091 Status: Offline Thanks Meter: 0 | Solution for SPI eeproms and PonyProg |
05-27-2000, 13:16 | #3 (permalink) |
Junior Member Join Date: May 2000 Location: Germany
Member: 1439 Status: Offline Thanks Meter: 0 | Hello, the datasheet of the X25650 (itīs the trium-eeprom) says that the chip has a supply voltage-range of 2.5 - 5 V. So I think it is a timing problem, not a voltageproblem. Thomas. |
05-29-2000, 00:12 | #4 (permalink) |
Freak Poster Join Date: Dec 1999 Location: 17 deg 49 min South
Member: 771 Status: Offline Thanks Meter: 9 | PonyProg and 95640 problem. I also had problems with reading 95640. I tried all what I find in the forums: -486 PC, -hundred times checked interface and connections on IC, -external battery voltage 5 V -capacitor between 5 V and ground, ............ ............ But I didn't solve problems but I LOSED ORIGINAL BIN FILE ! Finally I decrease voltage on 2.4 V (because I hadn't 2.7 Zener dode) and now all working perfect.I tried with Pony Prog versions: 1.13e, 1.16g and 1.17c and all give same results.I repeated reading and writing many times and every time all is OK. Trox, thanks... Regards PS Thomash,in electronic voltage and time are in connection.Isn't it? |
Heres a solution for alcatel s521a and s520a from america white sreen and unlock | CHAGUA | Infinity-Box | 0 | 09-12-2009 20:50 |
GOOD NEWS FOR ALL INDIAN CUSTOMERS : Unlock Solution for BIRD S198 and S199 is READY | Infinity-Box | Infinity-Box | 128 | 10-28-2007 17:19 |
Any Solutions for Audiovox 810 and Maxon NM2 ? | scum | Various | 4 | 04-25-2003 22:14 |
Any solution for unlock 922 and 930 s7???? | .:SkiR:. | Infineon C16X M51 & ARM7 M52 BASED | 3 | 12-19-2001 00:25 |
Solution for S10 Color and C25 with cable. | florin_m | x1x to x45/x50 | 2 | 09-12-1999 22:44 |
