Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
05-04-2000, 23:52 | #1 (permalink) |
Freak Poster Join Date: Dec 1999 Location: 17 deg 49 min South
Member: 771 Status: Offline Thanks Meter: 9 | Trium Astral - "Mitsubishi M4 Testmode" ??? I tried to unlocked it and I read EEprom 25640 with Pony Prog.I think that my programmer did't read EEprom good because I unlocked bin(used "Free2000") and wrote it again in EEprom and now I have on display Mitsubishi M4 Testmode Now I can only switch on and switch off phone,nothing more ! Have somebody same experience with that type of phone, and any idea how fix it??? Thanks in advance. Best regards |
05-05-2000, 13:49 | #4 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Bulgaria Kyustendil Age: 47
Member: 1191 Status: Offline Thanks Meter: 128 | Hi guys. Tell me more: Astral MT-140 ? Country in use ? (Germany, Bulgaria ...) Send me the ORIGINAL eeprom dump and your UNLOCKED dump. I try to unlock ORIGINAL dump and compare it with YOUR UNLOCKED. If there is different ... i send you unlocked WORKED dump. I unlock for now 7 Mitsubishi Astrl MT-140 with now problems. mail me at: [email protected] regards -= Svetli =- |
05-05-2000, 17:11 | #5 (permalink) |
Junior Member Join Date: Apr 2000 Location: Lithuania
Member: 1213 Status: Offline Thanks Meter: 0 | HI plruzza , Zoio and trox You used bad program Better use Unlocker by DIMO1999 this one works perfekt. If you vant you can send me your bin and I will send you it back unlocked. ------------------ ------------------------- ---POWERED BY SaSoKaS --- ------------------------- |
05-13-2000, 00:11 | #7 (permalink) | |
Insane Poster Join Date: Nov 1999
Member: 663 Status: Offline Thanks Meter: 0 | Quote:
Charlie | |
05-13-2000, 18:14 | #8 (permalink) |
Insane Poster Join Date: Mar 2000
Member: 1041 Status: Offline Thanks Meter: 0 | I have that problem too on pony prog. Don't know why, maybe a voltage problem, so i had decided to buy a programmer. Check on http://www.elnec.sk/ there are good and cheap eeprom programmers there or in www.crownhill.co.uk but these are more expensive... |
05-13-2000, 23:54 | #9 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | Hi I have many Triums unlocked, try this: I use Ponyprog with Inteface shematics from Ponyprog Webseite, but I use external Power. Many Comports have not enogh power for Programmer. Remove Eeprom from Trium, Put it in Programmer, solder or use Testsocket for SO8, tessocket can you buy from RS-Commponents for 40 EUR. Read Eeprom with Ponyprog, Are shure thats correct read, no ff or 00 overall. Save Binfile at secure place. Open Binfile with MT040.exe from DIMO click unlock SP and save with different !!!! name. Open Unlocked file with Ponyprog and write it to Prom. Thats all. Importent: Say your Phone "contact Provider" send me your Originalbin with your IMEI, and I send you a corect unlocked binfile. 15% of Triums need this special Solution. Jan Hi Speed PCs have trubble at SPI Proms and Ponyprog, you need a 486 or old Pentium. I try a 486/33 and it works Perfekt. My 450 MHz Pentium II work not succefull. [This message has been edited by jan (edited 14 May 2000).] |
05-22-2000, 01:46 | #10 (permalink) |
Junior Member Join Date: May 2000 Location: Germany
Member: 1439 Status: Offline Thanks Meter: 0 | Hi in your Message you are speaking from the MT040 form DIMO. Can you tell me where I can find this program. I need it for my own MTA. It is an old one, which can temporally be unlocked wit **04*.. But typing it everytime is boaring. Hope you can help me Thomas. [email protected] |
