Various AEG, Bosch/Dancall, Toshiba, Vitel, Maxon, Sendo .... and any other Phone which can't find any serving section for it...... |
04-19-2005, 15:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Sendo 570 and Smartclip Regards |
04-19-2005, 15:55 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | Check the battery contacts on the phone...Quite common on the 550 that the data lead "bends" one of the contacts....Worth a try, 'cos there is no other real reason for failure. |
04-20-2005, 22:40 | #3 (permalink) |
Crazy Poster Join Date: Jul 2004 Location: Cave Age: 41
Member: 73270 Status: Offline Thanks Meter: 8 | m570 unlocked with smartclip you should have read the smartclip manual carefully has it specifically states if you unlock sendo phones with smartclip you either use battery fully charged or just with the smartclip power from connector if you join both it will unlock phone but will screw the battery thats why it is not powering on just with the battery but if u plug it into the m550/570 ps2 connector kit it will poer on because the kit itself send power through the cable . if that is not the case then forget all i've just said |
07-29-2005, 13:01 | #8 (permalink) | |
No Life Poster Join Date: Dec 2001 Location: RP
Member: 7734 Status: Offline Thanks Meter: 0 | Hit mate, how long it take to finish sendo 570 unlocking? Quote:
07-29-2005, 13:56 | #9 (permalink) |
Member: 7734 Status: Offline Thanks Meter: 0 | Problem solved unlocked three times with bat on clip and 3/4 bat on phone. Still not good. Unlocked with power supply on clip and no bat on phone, unlocked in 2 sec. But problem is phone doesn't turn on. Soln: put back cover so that battery will have full contact to it's power pins hehehe. And Voila phone is unlocked and working fine.... so far! don't know what will happen next. Very unpredictable. WBR, blutac |
08-04-2005, 18:42 | #11 (permalink) | |
Major Poster Join Date: Sep 2004 Location: MADAGASCAR
Member: 82609 Status: Offline Thanks Meter: 1 | Quote:
could you tell me how to unlock sendo m570 with sendo test mode on start up before the logo appears , do u know what is this test mode I did 100's sendo but not that models roland | |
08-04-2005, 22:43 | #12 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Canary Islands, Spain. Age: 40
Member: 45456 Status: Offline Thanks Meter: 6 | the best solution for sendo.... Delok cheap solution, fast connection with the phone, and in two seconds can be unlock it All models, and best support regards |
prob unlocking sendo s360 with smartclip | HAMID-GSM | Smart-Clip | 2 | 06-10-2005 11:03 |
hi pls i need the unlock code for sendo s200 and other sendo phones | tiygyliar | Various | 1 | 05-26-2005 10:15 |
Possible to flash V550 to V620 with Smartmoto and SmartClip? | Mastah-GSi | Smart-Clip | 15 | 03-15-2005 15:52 |
New Philips: Xenium 9@9++ and others - SENDO 550 and others - Alcatel BF345/BG3 | DELOK | Main Sales Section | 0 | 10-18-2003 22:29 |
