9110 whith Twister www.twisterflasher.com DCT3-9110 but i have read ,that twister cann not flash 9110 is it true ? can twister that ? |
yes, not support 9110 at the moment. BR, epic |
:( :( :( :( a`m not happy :( |
and what a problemm ? to flash Phone part as 5110 whith DCT flasher it is possible (i had make it) and whith Twister not Faid Calc whith twister whithout problemm ,so so .............. @ Raskal it`s realy clever what you make , just erasure the 9110 from support ,realy clever |
Twister can all DCT3 , and 5110 too , so , from Software its no difference 9110-5110 |
but here need a little bit more. MAYBE will release in future flashing of this antiquarian rarity from 20th century ... |
IŽll bee waiting............ :( |
You have to remove the label underneath the 9110(i) battery and then you will see some test points that are needed for updating. So for servicing a 9110(i) only having the 9210(i) cable will not do the job. You need to have the special battery connector also. |
I can update PDA part whith MMC Card ,so i told hier about Phone part only |
This is for the MCU part the procedure: 1) Remove sticker with text underneath the battery 2) connect pin 15 and 16 together 3) insert battery In de PDA display are coming some dots and then the message 'relink mode enabled' Your EPOC is now stopped and the GSM part works a 5110 4) Flash it like you did a 5110 with Dejan flasher (you can use any sw you like, just choose 5110 as option) 5) Set FAID after flashing with EEPROMtools 3.1 6) Remove battery and open link between pin 15 and 16 7) should work now |
this is the way ,that i had done ,but the question is to flash whith TWISTER |
