Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 07-13-2005, 17:37   #1 (permalink)
kenichi's Avatar
Member: 6084
Thanks Meter: 4
7610 start-up fail
I have flashed with RH51_67PE505090.C2 and RH51PE505090.61, full factory and format with keypad ( * + 3 + Green + Power ON). Still shows "Phone start-up fail".
Any idea? No PM in support.
Old 07-14-2005, 14:36   #2 (permalink)
Member: 148237
i got the same problem after complete flash it waork when i start it second time it shows phone startup fail
Old 07-14-2005, 15:02   #3 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
First check IMEI while reading info if not just erased.
Also for 7610 there are some firmware versions with same fw number but not same launching date. Check wth *#0000# on working phones
So to being sure of that mcu & ppm are from same fw just uninstall it all and install once again just one package.
Max_B
Old 07-14-2005, 16:52   #4 (permalink)
Member: 94090
Thanks Meter: 26
1-format more than one.
2-u can try erase
flash mcu & ppm
wr pm, format ,unlock
Old 07-14-2005, 16:55   #5 (permalink)
Member: 94090
Thanks Meter: 26
deleted
Old 07-15-2005, 12:17   #6 (permalink)
Member: 143499
Thanks Meter: 10
after flash you have to make
FORMAT USER AREA
br corvinu
Old 07-15-2005, 14:15   #7 (permalink)
abadon's Avatar
Member: 134869
Thanks Meter: 8
FORMAT USER AREA
work 100% tested
Abadon
Old 07-16-2005, 15:19   #8 (permalink)
Member: 53041
hardware problem!!!
if u tired software,just try to reflow the uem and cpu,u will get the answer!!
7610 start up failed ikram tabassum1 Nokia Hardware & Hardware Repair 9 10-08-2008 10:59
7610 start-up failed ikram tabassum1 Nokia Hardware & Hardware Repair 5 09-23-2008 17:36
Nokia 7610 Start Up Failed Contact Retailer Solution RAJAN62073 Universalbox 3 07-17-2008 19:24
7610 start up fail amitks_in Nokia Hardware & Hardware Repair 11 09-04-2006 10:36
7610 start-up failed affter 30min pwoer off ashrafcell Nokia Hardware & Hardware Repair 6 06-11-2006 09:50
Page generated in 0.19481 seconds with 10 queries
