07-25-2006, 22:51 | #167 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Still thinking
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | bug with bb5 falshing mr. raskal tnx for crack but it's not working on bb5 model . i carck 2.01 version of dctxbb5 now i can see all new model but i try to flash or check buttuon 6630,6680,n70 working handset but same result boot error. then agin i install 2.00 dctxbb5 and it's working. then i copy flash folder from c:\programfile\nokia\phonix\flash and i crack 2.0.1 version on my othere pc and delete flsh folder and past 2.00 flsh folder . but same result boot error with bb5 handset. any idea or can u tell me where im wronge or plz fix the bug tnx u bye niki |
07-26-2006, 08:19 | #170 (permalink) | |
No Life Poster Join Date: Jan 2005 Location: GSM world Age: 49
Member: 111249 Status: Offline Thanks Meter: 531 | Quote:
BR | |
07-26-2006, 22:50 | #171 (permalink) |
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | prob with new hwk suit 30.0.1 i try to flash 6630 in new suit version 3.0.1 and it's result boot error then i try 6680 and my n70 result same boot error. then i rename my nokia foleder in program file and uninstall ufs suit and ufsx usb driver also and install suit 3.0.1 and it's freash installion then crack . but result still same boot error.agin i unistall 3.0.1 aqnd usb driver and install 3.00 version and carked it's start working with same cabel same ufs. don't now where is the prob . even i flash w 550 with 3.0.0 and it's done. in new verion 3.0.1 i'm not able to flash 6630,6680,and n70 itry these 3 hand set . but in 3.0.0 i can . did u gay's any one flash these 3 model with hwk 3.0.1 version with raskal new crack ? plz replay mr.raskal plz answare me tnx u niki |
07-27-2006, 05:59 | #172 (permalink) | |
Freak Poster Join Date: Apr 2006 Location: malaysia Age: 41
Member: 260519 Status: Offline Thanks Meter: 46 | Quote:
now you need uninstall this version ufs suite (v3.01) install UFS_Suite_Setup_v3.00.000_new.exe then use HWKKiller v2.0final paste it after uninstall it and install UFS_Suite_Setup_v03.01.000.exe then use HWKKiller21b.exe paste it again p/s: after uninstall suite setup no need delete anything believe me,because i just solved this problem BR | |
07-27-2006, 19:19 | #173 (permalink) |
Member: 139853 Status: Offline Sonork: 100.1590178 Thanks Meter: 46 | Oki I'll Try Okii mr jysmc i'll try tommarow and let u now tommarow and tnx u bro for help may be it's my mistake tnx u bye niki |
07-27-2006, 21:23 | #174 (permalink) |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | If you want to be sure of not your PC with d problem, Please check if you have any spyware, Do not just disable it but Uninstall it. Then Disable Anti-virus and startup options in the anti-virus. But remember you should not be online when takin these risk. Then restart your computer and try again. |
07-29-2006, 09:50 | #175 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
sorry mate, i just follow up cheaters way, i learned from them (HWK CHEATER TEAM) and i fuk them in the same way. i fuk the fukers, that i also fuk some other ones around them, well, i am sorry but life is like that some times at least the difference between me and HWK CHEATER team is clear, i am putting it free this hwk crack, i am not doing it for money, they are also selling clones as original and earning money from cheating. Seems they not happy with their own original product, seems they want more money. B.R., Raskal | |
07-29-2006, 10:05 | #176 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | sory 1 Question after install UFS_Suite_Setup_v3.01.000 use HWKKiller21b , i need have hwk cloend on my ufs or use soldring wrire solution ! o what ? i hope somone can give me litel explication |
07-29-2006, 10:36 | #178 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | Quote:
no pin short on pcb no trial hwk need patch all exe file 1 by 1 (dctx, kzf, sams...) | |
07-29-2006, 10:45 | #179 (permalink) | |
1.) buy screwdriver 2.) remove screw from box and take out pcb 3.) remove this HWK $hit 4.) look for next thashcan and throw hwk inside 5.) insert pcb in box again and put back the screw 6.) download hwk killer 1.2b and patch the latest exe 7.) success, no need any $hit hwk to make you box work with, no need short any cables | |
07-29-2006, 10:47 | #180 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Rawalpindi,Pakistan Age: 45
Member: 133099 Status: Offline Sonork: 100.1582860 Thanks Meter: 18 | Yes no need of short pin method nor needed trial hwk....u only need hwk raskulator and updated firmware of ufsx box..... After that apply patch to individual files of ufs suit to work..... and enjoy |
usf setup3.01 can't work with killer 2.1b | denard | Twisterflasher | 8 | 10-06-2006 12:27 |
Anyone tested Nokia 6280 flash on HWK Killer 2.1b??? | y2khjh | Twisterflasher | 5 | 07-24-2006 13:57 |
HWK Killer 2.0 final release, download from here | Raskal | Twisterflasher | 192 | 07-03-2006 15:44 |
