07-19-2005, 14:43 | #1 (permalink) |
Major Poster Join Date: Nov 2004 Age: 42
Member: 89745 Status: Offline Thanks Meter: 0 | 2600 dead after failed flash I was flashing my 2600 when about half through there was an error and the procedure was stopped. now the phone will not power up & is completly dead. any ideas what to do? Thankx Rob. |
07-22-2005, 15:49 | #3 (permalink) |
Member: 89745 Status: Offline Thanks Meter: 0 | tryed but because the pevious flash erased some stuff from the phone before it failed i get this message when i try to flash again: 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320 Algorithm: u_amd.fia Algorithm Ok, MSID: 84DE82BB94D351D65AFCDF62D6 Decoded MSID: 3E4EBAE9-00405B84-A8000000 Encoded FAID: AA307459-FBDFA797-919B3F39 Erasing: 0x01000000-0x0100FFFF ... Erasing Error: 10, at: 0x01000000-0x0100FFFF, FFFFFF, Time: 00:06 Process Failed, Repowering Mobile any ideas what to to? Thankx Rob. |
08-07-2005, 21:57 | #9 (permalink) |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | This situation happens often with 2600 handsets and not only with 3-rd party flasher, also original equipment kill it in same way. Doctormike is right, you have to rebuild imei. |
08-08-2005, 10:08 | #10 (permalink) |
No Life Poster Join Date: Jul 2004 Age: 38
Member: 71144 Status: Offline Thanks Meter: 12 | real way nly with ufs3 box select model on the DTE-1 (D211) press the erase flash key ok and erase full flash second :write full flash and cnt with (select the 2600) ver 4.42 1000000000000000000 % ok |
08-08-2005, 15:32 | #11 (permalink) |
Member: 89745 Status: Offline Thanks Meter: 0 | i tryed with "erase flash memory" with DTE-1 (D211) and pressed ok on "adjust start adress" & "adjust end adress" and after that i flash the phone normally with Rh-59(2600) but still the same, "sim invalid". what am i doing wrong? Thankx Rob. |
Nokia 5220 dead after failed flash | Ralcala | Universalbox | 1 | 08-29-2009 17:39 |
e900 dead after failed flash | dawuda1 | Samsung Hardware Repair | 1 | 06-16-2008 19:11 |
W810 dead after failed flash (Error flashing block at address: 0x444B0000) | Xflame | Cruiser Suite | 12 | 12-11-2006 04:27 |
W810 dead after failed flash | Xflame | Cruiser Suite | 0 | 08-15-2006 14:51 |
6270 dead after failed flash... can't revive. Help! | kraftfahrzeug | Nokia Base Band 5 ( BB-5 ) | 3 | 08-11-2006 08:58 |
