Problems reading PM area. Today I saw the new version 1.21 installer suite for download. Here goes, I downloaded it and installed it. Decided I would read the PM of a 7250i so that I could repair and knackered one... Well for some strange reason it keeps failing whilst reading PM (either in Absoloute mode or starting @ 0 to 255) Can someone pls help, whats the point of adding a feature if it won't work correctly. |
I make a pm file on 1100 no problem will check other models as i get them |
Guy, disconnect cable from fone and box , connect back, try again as much and see what happens ;) Br Didi |
Hmm... strange, have tried and tried with this 7250i, even tried with a brand new handset to read it, but still no joy, yes it does read another handset model fine, just the 7250i it wont read. |
2 Attachment(s) I dont know where you get error but here is screen shots of 100% made pm file with 7250i |
What did you read the PM as, Absoloute or ID 0 to 255. |
yes i only make a pm reading from 0 - 255 im NOT using read absolute values there is no special setting have a look at mine to see maybe i do something diierent to you but standard settings should be fine \ |
Gets to value 11 and value 12 and sometimes value 15 and then it konks out. |
Read problems here too. 6600 PM reading failed even with >30 attempts, stops at various values. Totally unstable operation... |
This is not joke, i mean it. |
i sure you have done this but check your connections and cables try to read a pm file with easy phone like 3310 and if still have problem make a screenshot here, i dont think your twister is faulty first make a screen shot you say you can read other models fine so then some small problem maybe |
I see New feature - New problem ::(( So 1. PM -- Permanent Memory 2. ID -- Group ID 3. Record -- Record in Current Id 4. Absolute -- Abbsolute Offset in FLASH memory to PM start 5. Protected Area -- Area which NMP do not allow to read for R&D user --- Hints Open PM file with text editor and look what is inside Group[158] in mostly cases is Gallery picture files |
maybe some bugs. i tried on N7600 and 3650. it stops on different areas. tried on 98se and xp. i'm sure ufs team will correct this on next update. regards, |
