05-12-2004, 10:06 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Age: 43
Member: 58059 Status: Offline Thanks Meter: 0 | Problems reading PM area. Here goes, I downloaded it and installed it. Decided I would read the PM of a 7250i so that I could repair and knackered one... Well for some strange reason it keeps failing whilst reading PM (either in Absoloute mode or starting @ 0 to 255) Can someone pls help, whats the point of adding a feature if it won't work correctly. |
05-13-2004, 10:18 | #4 (permalink) | |
Member: 58059 Status: Offline Thanks Meter: 0 | Quote:
Hmm... strange, have tried and tried with this 7250i, even tried with a brand new handset to read it, but still no joy, yes it does read another handset model fine, just the 7250i it wont read. | |
05-13-2004, 15:03 | #6 (permalink) | |
What did you read the PM as, Absoloute or ID 0 to 255. | |
05-13-2004, 15:25 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 45
Member: 54419 Status: Offline Thanks Meter: 0 | yes i only make a pm reading from 0 - 255 im NOT using read absolute values there is no special setting have a look at mine to see maybe i do something diierent to you but standard settings should be fine \ |
05-13-2004, 15:32 | #8 (permalink) | |
05-13-2004, 15:44 | #9 (permalink) | |
Gets to value 11 and value 12 and sometimes value 15 and then it konks out. | |
05-14-2004, 01:00 | #11 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
This is not joke, i mean it. | |
05-15-2004, 09:26 | #12 (permalink) | |
05-15-2004, 10:48 | #13 (permalink) |
Member: 54419 Status: Offline Thanks Meter: 0 | i sure you have done this but check your connections and cables try to read a pm file with easy phone like 3310 and if still have problem make a screenshot here, i dont think your twister is faulty first make a screen shot you say you can read other models fine so then some small problem maybe |
05-16-2004, 04:25 | #14 (permalink) |
Product Supporter Join Date: Nov 2002 Location: usd Age: 64
Member: 17804 Status: Offline Sonork: 100.27310 Thanks Meter: 1,075 | I see New feature - New problem :( So 1. PM -- Permanent Memory 2. ID -- Group ID 3. Record -- Record in Current Id 4. Absolute -- Abbsolute Offset in FLASH memory to PM start 5. Protected Area -- Area which NMP do not allow to read for R&D user --- Hints Open PM file with text editor and look what is inside Group[158] in mostly cases is Gallery picture files |
05-16-2004, 09:32 | #15 (permalink) |
Freak Poster Join Date: Jun 2000 Location: In front of pc
Member: 1585 Status: Offline Thanks Meter: 15 | maybe some bugs. i tried on N7600 and 3650. it stops on different areas. tried on 98se and xp. i'm sure ufs team will correct this on next update. regards, |
Problem reading PM | rudyandremely | Nokia Base Band 5 ( BB-5 ) | 0 | 12-15-2009 20:37 |
Running Into a Problem Reading PM using NSS on Nokia 6555b | SpikeyPsyche | Nokia Hardware & Hardware Repair | 0 | 05-09-2009 16:32 |
Running Into a Problem Reading PM using NSS on Nokia 6555b | SpikeyPsyche | Nokia Base Band 5 ( BB-5 ) | 1 | 05-06-2009 01:41 |
