03-21-2004, 14:21 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Earth
Member: 38573 Status: Offline Thanks Meter: 0 | Twister problem with Nokia 8850!!!! 1st boot err: Bad Resp DCT3 and I click check, it gave me the error 1st boot err: Bad Resp DCT3 1st Boot Err: Bad Resp UPP, 02 FF FF 72 Rebooting Mobile |
03-21-2004, 14:31 | #2 (permalink) |
Freak Poster Join Date: Mar 2001
Member: 3620 Status: Offline Thanks Meter: 0 | and what is happend when you press "Check" button? it can boot the phone? you can check manual or FAQ if you have, but on your place, first i will be checking cables with the schematic (or just pins from phone connector)... or even try to use your cable + original battery from phone (if that is possible with your cable). BR, Vanitas 69 |
03-21-2004, 15:16 | #3 (permalink) |
Member: 38573 Status: Offline Thanks Meter: 0 | First of all, with the cable I can get the info from the phone. I can rebulid the IMEI, will that mean the cable works fine??? And I can't find the cable schematic for 8850. Nothing happend, just showed me the error. and reboot the phone. |
03-22-2004, 08:32 | #5 (permalink) | |
Banned Join Date: Oct 1999 Age: 55
Member: 563 Status: Offline Thanks Meter: 22,328 | Quote:
Please verify schematic and take care the cable have propper contact with contacts on phones pcb !!! | |
03-22-2004, 09:21 | #6 (permalink) | |
Major Poster Join Date: Jan 2004
Member: 48553 Status: Offline Thanks Meter: 0 | Quote:
when i extracted simcard then everything was ok. m-t | |
03-22-2004, 10:38 | #7 (permalink) | |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Quote:
Are you connecting the phone to Twister box via CFA6 or MRT-2 cable and gender changer? Can you flash other DCT3 phones? Are DCT4 ok? Odia. | |
03-22-2004, 14:02 | #8 (permalink) |
Member: 38573 Status: Offline Thanks Meter: 0 | Hi Odia. The twister works great with my SonyEricsson T610. Haven't try the DCT3 and DCT4 yet. I'll check the cable schematic first. @major-tom, thx for your help. but there's no sim card in the phone while i did the operation. |
03-22-2004, 14:17 | #9 (permalink) |
Member: 38573 Status: Offline Thanks Meter: 0 | just checked with the 8210 cable schematic, the only different to the cable schematic is there's no diode in the cable. The contact on PCB should be fine, because it read the info from the phone, and change IMEI as well. I also have a look on the PCB, I can see the contact points there. |
03-22-2004, 18:16 | #11 (permalink) | |
The diode is only required for 5210. Good you have it working, maybe you disturbe something while checking cable and now its ok. Odia. | |
03-23-2004, 02:05 | #12 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Copenhagen, Denmark Age: 59
Member: 51434 Status: Offline Thanks Meter: 16 | Same with Nokia 5210 Hi... I have same problem with a 5210. I have mont. diode, and make a cable tjek, it's OK. The only thing Im not sure of, is the connection to phone, but it's seems to be good. The connection to phone is via MRT-2 cable and gender changer. I can read INFO, but if I try CHECK I get this : 1st Boot Err: Bad Resp DCT3 1st Boot Err: Bad Resp UPP, FF FF FF 72 Rebooting Mobile I have tried a 6150 and it's working fine. /Henrik |
03-23-2004, 02:08 | #13 (permalink) | |
03-23-2004, 09:34 | #14 (permalink) | |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | Quote:
there is sollution for this problem...after i made the necessary modifications i am now able to flash all DCT 3 phones that use the 8850 connector without problems. sollution can be found in this twister section for the ones interested into it...it is not advertised by mr Rascal because he never likes to admit that he makes mistakes | |
03-23-2004, 09:41 | #15 (permalink) | |
Unlocking problem with Nokia 2610 but not with Nokia 2310 | simclub1 | MT-BOX | 28 | 03-14-2007 11:26 |
Battery problem with nokia handset with a proper Sim card | Vijay Arora | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 05-09-2006 06:39 |
Twister problem with samsung and SE | jac107 | Twisterflasher | 0 | 05-16-2005 21:36 |
i have a Problem With Nokia 3300 And One Problem Too : 7250i Phone Program... | Sky-Dancer | Nokia Multimedia | 2 | 10-27-2003 18:49 |
Maybe anybody can help with Nokia 8850 some problems | wukaz | Nokia Hardware & Hardware Repair | 1 | 03-07-2002 19:30 |
