05-20-2006, 12:44 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: fast flowing water Age: 47
Member: 158648 Status: Offline Thanks Meter: 3 | d500 charging on its own does anybody have or know the charging ways of d500....i have 1 that shows charging on its own..i have changed the j2 diode and all the other small components around it...any clue? |
05-21-2006, 16:48 | #3 (permalink) |
Junior Member Join Date: Mar 2006
Member: 249320 Status: Offline Thanks Meter: 1 | i have c100. when powered it says battery empty. when the battery is used in a good c100 the bat is full. i have flashed and changed u202 still the same. pl help if u have a solution. thanks |
05-21-2006, 16:55 | #4 (permalink) |
The Following User Says Thank You to fabumukorong For This Useful Post: |
05-22-2006, 08:31 | #6 (permalink) | |
Member: 158648 Status: Offline Thanks Meter: 3 | d500 charging problem Quote:
thanxxxx alot....your solution worked 100% | |
03-08-2007, 08:21 | #11 (permalink) | |
No Life Poster Join Date: May 2005 Location: Timisoara Age: 43
Member: 146635 Status: Offline Sonork: 100.1651273 Thanks Meter: 261 | Quote:
try this solution warning: if only remove filter and not change, phone WILL WORK OK, but no longer communicate with computer(you can no longer flash/read phone) Last edited by zullu2004; 03-08-2007 at 08:38. | |
03-09-2007, 18:12 | #13 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Aussie Age: 54
Member: 15355 Status: Offline Thanks Meter: 4 | give the filter as posted by zullu2004 a good clean with cleaning solution (with a toothbrush) seems to get corrosion under filter,i had already cleaned pcb in ultrasonic bath but it did not fix it but after a good srub with a brush it worked fine. |
09-17-2007, 05:45 | #14 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 47
Member: 196194 Status: Offline Thanks Meter: 47 | i applied little fluxm on ic U500 AND THEN SLITLY SHAKE THE IC.. ALSO RESOLDER ALL THE CHARGING CONNECTOR PIN.. ITS 100% OK NOW.. thnks to all regards! |
09-17-2007, 08:07 | #15 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: http://www.paybox.me/r/mourad1 Age: 47
Member: 155016 Status: Offline Thanks Meter: 130 | Quote:
Most likely is Vbat+ shorted to VExt(charging pin) , hence charging still takes place even no charger is actually plaugged in ...so to cure that ...simply clean/remove Sytem connector and proceed inspection straight to the Charging Circuit ...which makes sense from a technical point of view ..and this holds true whenever u have such a problem ,regardless ur phone model/brand. B.R.............. | |
MY N70 on O2 is sending mms on its own! whats wrong with it. | 1508 | Nokia Base Band 5 ( BB-5 ) | 5 | 07-11-2006 14:44 |
3410 rebooting on its own | toptech | Nokia Hardware & Hardware Repair | 1 | 09-23-2005 20:32 |
mw3020 charging on its own | pmapuranga | Sagem Hardware Repair Area | 3 | 09-30-2003 11:30 |
My c35 switches off on its own | reo | x1x to x45/x50 | 1 | 04-22-2001 21:58 |
My c35 switches off on its own | reo | x1x to x45/x50 | 3 | 04-22-2001 16:52 |
