05-21-2006, 00:35 | #1 (permalink) |
Junior Member Join Date: Mar 2006
Member: 250611 Status: Offline Thanks Meter: 0 | D500 keyboard problem Thanks in advance Cass23 |
05-21-2006, 18:48 | #2 (permalink) |
Freak Poster Join Date: Jul 2005 Location: fast flowing water Age: 47
Member: 158648 Status: Offline Thanks Meter: 3 | d500 scroll button not working hi friend had a problem like this before...usually broken tracks on the lcd board...but what i did was replaced the lcd board |
The Following User Says Thank You to caddisfly For This Useful Post: |
05-22-2006, 22:37 | #3 (permalink) |
Member: 250611 Status: Offline Thanks Meter: 0 | Hi, thanks to Ogre, I have found the problem. The tracks on the LCD where the buttons connect to make a circuit had started to come away from the board. I cleaned them up a little bit with a blade and stuck the down again. (Short term solution). Works ok at the moment but I need to know what I can stick them down correctly. I understand that I cannot use certian type of adhesive because of the acid content could corrode the board. Is there a type of adhesive that is needed? Thanks for the reply Cass23 |
6210 keyboard problem | Gold_Horn | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-16-2002 21:41 |
S35 keyboard problem | vva | x1x to x45/x50 | 0 | 11-15-2002 13:57 |
T20 keyboard problem | Lukas123 | Sony Ericsson Hardware Repair | 1 | 11-13-2002 16:19 |
Keyboard problem | Jt | x1x to x45/x50 | 1 | 07-11-2002 01:18 |
S35 keyboard problem | dagsm | x1x to x45/x50 | 1 | 02-16-2002 18:35 |
