05-05-2005, 07:54 | #1 (permalink) |
Registered User Join Date: Apr 2004 Location: BiH RS
Member: 64168 Status: Offline Thanks Meter: 3 | d500 "please slide up" |
06-29-2005, 09:10 | #6 (permalink) |
Freak Poster Join Date: Sep 2001 Location: GERMANY
Member: 6420 Status: Offline Thanks Meter: 8 | i have repaired many phones with same problem it s hapen generally when you change front ...... there is a magnetic in the amortissort between the front and rear side that is the probleme .... for me i insert a little magnetic inside the phone down side and it work 100000000000 br |
11-02-2005, 13:06 | #7 (permalink) |
Freak Poster Join Date: Sep 2002 Location: UK
Member: 15399 Status: Offline Thanks Meter: 3 | I am having the opposite problem. My D500 thinks the is is constanly open, the camera works even if the slide is down, but i can just see black as the camera is covered. Also my B\T is not working, it comes up with activation error. The I\R eye has been snapped off the board, would this be causing the B\T not to work? Last edited by Foneshack; 11-02-2005 at 14:49. |
09-17-2006, 19:04 | #9 (permalink) | |
Freak Poster Join Date: Sep 2005
Member: 177088 Status: Offline Thanks Meter: 15 | Quote:
09-17-2006, 22:14 | #11 (permalink) |
Junior Member Join Date: Sep 2006
Member: 352034 Status: Offline Thanks Meter: 0 | Slider Problem I think a thank you is in order here, I have been having the same problem with the slider, I was pushing it up and no action. I tought it was the flex ribbon but I was wrong it was the magnet situated under a small film of tape. I encountered this problem trying to change my old housing to a new one. So bear in mind when you change the housing move the magent too. An easy way to fing the maget is to use a small piece of metal like a small spring and try to lift it with the part of the phone that contains the LCD, it will stick somewhere at the bottom. Them magent can be taken out with some from from the opposite site. Again thanks to the guys who found out about this first |
(PLEASE SLIDE UP) d500 | S.SHANTHIKUMAR | Samsung Hardware Repair | 7 | 03-09-2009 03:22 |
d500 please slide up when taking photo? | jtg | Samsung Hardware Repair | 11 | 11-11-2006 07:50 |
D500 Active Slide Not Working Solution! | DABOSS | Samsung Hardware Repair | 3 | 12-01-2005 00:54 |
D500 Loose Slide Cover | Shooter | Samsung Hardware Repair | 1 | 07-06-2005 09:08 |
D500 flex cable and sliding mechanism wanted ASAP | gjurobrod | Wanted Products | 2 | 06-24-2005 19:00 |
