Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 01-07-2008, 23:31   #1 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Thumbs down E250 LCD problem and strangest problem
hi all.
got from a client an E250 (let me call it phone A) that once powered up shows the screen mixed up. at first i thought it was the flex but was not, changed the screen and still the same. Flashed it but still the same. Then i tried to use another brand new working SAME model (let me call it phone B) and exchange parts and this is where i got really confused and stranded
I used the upper part together with flex from Phone B with the board of phone A and the result was NO POWER. Used the flex and upper part of Phone A on the board of Phone B and result was sound only. Changing the flex that was used in Phone B resulted in no power. Replacing the original flex in phone B powered it up ok. Definetly even if its the same model there is some mismatch in them. I guess that Phone A needs another type of screen that is not compatible with the normal ones. The problem is which is it and how can i know?
Anyone can shed some light on this problem pls?
thanks
Old 05-14-2008, 20:45   #2 (permalink)
Member: 196126
Thanks Meter: 80
Hi
E250 E250D its a problem I think
Old 05-14-2008, 21:02   #3 (permalink)
joe cellular's Avatar
Member: 340957
Thanks Meter: 65
1oo% rite. also check da color off board. der 2 types. check firmware of da brand new 1
Old 05-14-2008, 22:40   #4 (permalink)
Member: 11325
Thanks Meter: 266
could not find a working LCD for this old board. In fact as you well said they have different screen types.
thanks
samsung e250 no sound and ear problem rehman_mani Samsung Hardware Repair 5 01-17-2009 15:21
3110c lcd white and keypad problem techark Nokia Hardware & Hardware Repair 2 09-02-2008 05:47
C65 new probleme and Big problem riadh_tn SIEM Service Tools 10 07-14-2006 13:32
Ngage Classic~Low Memory Problem and installation problem ckwong08 WD2 & APE (Symbian Phones) 3 11-10-2005 03:29
C65 new probleme and Big problem riadh_tn S-Gold Based Phones 5 09-10-2005 14:22
Page generated in 0.13807 seconds with 9 queries
