Galaxy S5 Mini G800F No Screen Hi Guys, have a Galaxy S5 Mini which falling down. no screen. changed lcd already. could backlight fuse faulty? any Ideas? |
S5 mini has no backlight circuit ....it is Amoled display...try to look for filters if they are in ordnung there regards |
thanks. do you know the position of this Filters? |
usually they are located next to display connector regards |
i found a broken unit now. see attached picīs. i think it is a coil and i can bridge the pads? https://picload.org/image/rocparpw/00017.jpg https://picload.org/image/rocparwr/00023.jpg |
itīs the same like here :http://forum.gsmhosting.com/vbb/f258...g800f-2013839/ |
you can`t just track the pads..look for another one in another mainboard... regards |
donīt have another one :( if i would have the schematics.... |
1 Attachment(s) Quote:
samsung galaxy s5 mini sm-G800F display solution phone falls .... check his lcd connector (resolder if necessary) check one by one its working voltage lcd check emi filter (MIPI) ... or it could be in jumper missing part L5000 (inductor smd) with values: 10 uH , 20%, 2.0X1.6X1.0MM |
Thanks. Found L5000 missing. Ordered Spare Part. |
S5 mini emi filter needed where i find one ]Thanks. Found L5000 missing. Ordered Spare Part.[/QUOTE] YOU WHER I CAN FIND ONE FOR MY S5 MNIN I GOT EXACTLY SAME ISSUE |
