08-27-2015, 11:18 | #1 (permalink) |
Insane Poster Join Date: Aug 2015
Member: 2450528 Status: Offline Thanks Meter: 3 | GT-I9300I Touch Screen Not Working i need help,what will be the problem? Thanks.. |
09-04-2015, 06:39 | #8 (permalink) |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | pin 3 is TSP_SDA_1.8V, pin 4 TSP_SCL_1.8V ,pin 8 TSP_nINT are directly comes from cpu. whereas pin 10 TSP_AVDD_3.3V volts comes from power ic. for one volt for touchscreen opration i.e. 1.80v i have doubt? from where its come? I m sure there is no any seprate touch ic. near lcd connector there are 3 resistors for TSP_SDA_1.8V, TSP_SCL_1.8V, and TSP_nINT. find it accordind to pin no. than another side of all these 3 resistors are common and there must be TSP_VDD_1.8V. If volt is absent than give jumpper with VCC_1.8V_AP. Also measure ohms of pin 3 with pin 4 it must be 2k ohms or little more. If it less than 2k ohms than those two line shorted below cpu.than its impossible. Did you measured volt TSP_AVDD_3.3V? please give me all needed pin reading (volts and multimeter ). And also visit here http://forum.gsmhosting.com/vbb/f258...cated-1936168/ |
