01-16-2005, 11:52 | #1 (permalink) |
Insane Poster Join Date: Mar 2004 Age: 46
Member: 57952 Status: Offline Thanks Meter: 6 | hot air and flat cable at e700 i had change about 15 pieces (at ~240degrees)and a lot from them he has broken(ear shortly,main or external display faulty,camera ) |
01-16-2005, 19:39 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | i have done maybe 20+ flat cable changes and only ever broken 1 small LCD same temperature you are using, it maybe a fault in your positioning of the LCD cable when re-attaching |
01-16-2005, 22:40 | #4 (permalink) |
Freak Poster Join Date: Dec 2002 Location: Serbia Age: 48
Member: 18812 Status: Offline Thanks Meter: 1 | I done it a lot also but have maby 10 to 15 bad flat cables. That cables was bad before even I try to mount them usualy light problems and camera. It depends how good supplier u have, in this case mine is bad. |
01-17-2005, 00:44 | #5 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | well, how do change flex on E700 ?? with Hot Air ? well can u post any pict ? with only 240C u can solder it ? great. i think about soldering it with solder iron , but want to be sure how to do it without damaging LCDs Pali |
01-17-2005, 15:02 | #8 (permalink) |
Member: 57952 Status: Offline Thanks Meter: 6 | i desolder both display with hot air but i solder them with iron.i change and connector with hot air too.is possible the flat cable from china is it better then from turkey. |
01-17-2005, 23:52 | #9 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | very nice.. this is very important for changing flex cable on E700 .. what will be next? Changing flex on A800, S100 ...etc? that would be great and helpful Pali |
01-18-2005, 00:07 | #10 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | suplliers in Serbia are buying cheapest flet cables in china,that's why we CAN"T change it with hot air,only manualy with iron.they are very sensitive to heat |
01-18-2005, 00:25 | #11 (permalink) |
01-21-2005, 13:21 | #12 (permalink) | |
Member: 57952 Status: Offline Thanks Meter: 6 | Quote:
01-21-2005, 14:45 | #13 (permalink) |
No Life Poster Join Date: Apr 2001 Location: on the beach
Member: 4160 Status: Offline Thanks Meter: 1 | it exist many qualities of flat cables,some of them doesn't work even new . At first you must check the flex with microscope and if is okey,so you use Hot air or Infrared and also a good solder iron (Weller,Salomon...) . If you have Parkinson so it's a little bite hard BR |
01-21-2005, 14:56 | #14 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Prijepolje-Durmitor, Serbia And Montenegro Age: 46
Member: 19987 Status: Offline Thanks Meter: 27 | Quote:
Regards Mackie | |
Looking for Steinel nozzels hot air and RJ45 with 10 pin | Ian | Hardware Repair Item Wanted | 3 | 08-27-2008 19:59 |
NEW HOT PRICE AND NEW PRODUCTS at www.esichip.com | GsmSoft_Team | Main Sales Section | 0 | 08-09-2008 09:54 |
e700 no light after change flat cable | hightechsquare | Samsung Hardware Repair | 18 | 03-13-2007 22:29 |
E700-E710 flat cable | KRIZA | Samsung Hardware Repair | 3 | 08-23-2004 16:48 |
Hot Air And L.e.d's | mujie | Hardware Repair by brands | 3 | 09-15-2002 20:42 |
