10-21-2015, 05:19 | #196 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2463816 Status: Offline Thanks Meter: 0 | |
10-22-2015, 06:01 | #198 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
11-19-2015, 13:54 | #202 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2007682 Status: Offline Thanks Meter: 0 | My phone has the short-circuit symptoms ie., one day it just wouldn't start and when I tested pins 1 & 3 they were crossing. However, someone pointed out to me that if there was a short-circuit then the battery would be flat, which it wasn't. Can someone advise on this. |
12-30-2015, 20:42 | #205 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Macedonia
Member: 2430631 Status: Offline Thanks Meter: 40 | I opened a thread earlier today for dead i9105p but i see that thread is still active. Can someone point out which capacitor to remove on the i9105p board because it aint the same. Thank you |
04-29-2016, 10:37 | #207 (permalink) |
Member: 2465780 Status: Offline Thanks Meter: 1 | HY! Samnsung S2 i9100 with short on power from battery ,atm desoldered diode "As " beside battery conn. ;any specs about this smd Got worked that diode on table is an simply 1n4148 Anyway I can't put any pics atm as I'm new user Last edited by vyktormvm; 05-22-2016 at 17:56. |
05-21-2016, 17:55 | #208 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2550091 Status: Offline Thanks Meter: 0 | Recurrent problem Hi, I have about 5 i9100 mainboards with the same problem. The way to reproduce the issue is put a low charged battery in it, turn it on and, while it is processing something( a incomming call or a game for example) and the battery is about to be 0%, connect it to a charger. Comparing them to a working board shows that the only diff when not powered on is that the bad ones have 0v on capacitor c504. I´d had already replaced all CIs on the board, except from the exynos and the memory. Do you have any clue on this issue? Att, Lincoln. |
05-21-2016, 18:11 | #209 (permalink) |
Member: 2550091 Status: Offline Thanks Meter: 0 | edit.: As I said, ive already tested the u501 on a working board and resoldered it back,the 2.0v on the c504 cames from a5 and b5 pins on the u501. It´s not the u501, but i got no clue on the issue. |
