samsung galaxy s4 mini gt-9195 no power on hello guys i have the s4 mini with no power on... so im messuring the battery connector with my multimeter on diode mode and i have 1320 with + to + and - to - also i have 385 with + to - and - to + so i plug in my power supply and i have no power draw at 4 volts...after pressing the power button i have 60 mA draw..nothing else so far i have test and messure capacitors and didnt find someone damaged. what you think for my problem? also i need the electronic schematic for this board thanks in advance guys |
1-check a heating ic and replace it |
yea i have already look for this.... i feel power ic and emmc ic little hot but im not sure cause the current draw is only 60mA |
Or you can as well use freeze spray 75 it will show you faster heating ic and components |
My advice for you : Software: Flash a boot file Hardware: 1- clean your motherboard with ultrasonic cleaner with tiner liquid 2- check input and output voltage for power ic (pmic) same as schematic 3-resolder power ic(pmic) using past not flux not a long duration cause past can not stand longer time like the flux and of course you know the difference between this two 4-use z3x jtage to repaire emmc 5-replace emmc |
i really need the schematic to anderstand the current path and all that...or the schematis of the power ic atleast |
i have no schematic for power ic...can help me with this please? |
hmm something whorng with the link? |
Copy the link and past to yor browser it will open |
didnt open but i find the way... there is no schematic for gt 9195 :( thank you for your time greetings |
hello friend im waiting some tools and stuff to start |
