Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 07-13-2017, 08:05   #1 (permalink)
Member: 2731548
samsung galaxy s4 mini gt-9195 no power on
hello guys
i have the s4 mini with no power on...
so im messuring the battery connector with my multimeter on diode mode and i have 1320 with + to + and - to -
also i have 385 with + to - and - to +
so i plug in my power supply and i have no power draw at 4 volts...after pressing the power button i have 60 mA draw..nothing else
so far i have test and messure capacitors and didnt find someone damaged.
what you think for my problem?
also i need the electronic schematic for this board
thanks in advance guys
Old 07-13-2017, 12:13   #2 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
1-check a heating ic and replace it
The Following User Says Thank You to habibboxes For This Useful Post:
Old 07-13-2017, 13:07   #3 (permalink)
Member: 2731548
thank you for the replay
yea i have already look for this....
i feel power ic and emmc ic little hot but im not sure cause the current draw is only 60mA
Old 07-13-2017, 13:51   #4 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
Put the power supply voltage at 4.3v and check
Or you can as well use freeze spray 75 it will show you faster heating ic and components
Old 07-13-2017, 14:02   #5 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
My advice for you :
Software:
Flash a boot file
Hardware:
1- clean your motherboard with ultrasonic cleaner with tiner liquid
2- check input and output voltage for power ic (pmic) same as schematic
3-resolder power ic(pmic) using past not flux not a long duration cause past can not stand longer time like the flux and of course you know the difference between this two
4-use z3x jtage to repaire emmc
5-replace emmc
Old 07-13-2017, 14:04   #6 (permalink)
Member: 2731548
i have the same power draw at 4.3 so the heating procces is slow...
i really need the schematic to anderstand the current path and all that...or the schematis of the power ic atleast
Old 07-13-2017, 14:27   #7 (permalink)
Member: 2731548
My advice for you :
Software:
Flash a boot file
Hardware:
5-replace emmc
thank you for your time my friend....
i have no schematic for power ic...can help me with this please?
Old 07-13-2017, 21:49   #8 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
https://000777software.********.com/...sheet.html?m=1
Old 07-13-2017, 22:43   #9 (permalink)
Member: 2731548
hmm something whorng with the link?
Old 07-14-2017, 00:58   #10 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
Old 07-14-2017, 00:59   #11 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
http://https://000777software.******...sheet.html?m=1
Old 07-14-2017, 01:02   #12 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
Copy the link and past to yor browser it will open
Old 07-14-2017, 01:28   #13 (permalink)
Member: 2731548
didnt open but i find the way...
there is no schematic for gt 9195
greetings
Old 07-14-2017, 21:24   #14 (permalink)
Member: 1869842
Sonork: 100.1625473
Thanks Meter: 186
greetings
did you solve the probleme and how????
Old 07-15-2017, 00:13   #15 (permalink)
Member: 2731548
hello friend
im waiting some tools and stuff to start
Page generated in 0.20734 seconds with 8 queries
