12-22-2016, 17:03 | #64 (permalink) |
Freak Poster Join Date: Feb 2015 Location: Syria-Aleppo
Member: 2346672 Status: Offline Sonork: 1671045 :Abdohurbli Thanks Meter: 25 | I'm Facing Strange Error here .. S6 Edge Stuck on Boot logo .. for the First time I though it's Software problem ... So I tried the Next : 1- Full Firmware 2- Latest Firmware " Smart Switch " 3- ENG Firmware 4- Root the Same Stuck on Boot Logo ... what I've found later on when I flash it TWRP Recovery : I'm There On The Recovery Screen ! But Few Sec. Later .. " About 4 Sec " device is Freeze there ...and for that I Did Force Restart .. then stuck again on boot ... what is this ? Is it eMMC ? Or what ? I believe it hardware Error ! and how To solve it ? BTW I have the Same Error with S7 Edge " G935F |
12-29-2016, 14:12 | #65 (permalink) |
No Life Poster Join Date: Oct 2012 Location: Republic of Serenissima
Member: 1825965 Status: Offline Thanks Meter: 874 | G925F display flickering hello any advice for flickering screen on G925F ? already tried with another display already tried another battery the problem is visible after 30 seconds phone is power on |
01-07-2017, 03:05 | #68 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | g925f rotation+calling sensor not working already change ribbon but same change both ic above cpu but still same |
The Following User Says Thank You to HUM For This Useful Post: |
01-07-2017, 16:18 | #69 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1135025 Status: Offline Thanks Meter: 11 | first check the sensor hub and the other sensors in testmenu (*#0*#), if all sensor are not working check the rcv(earspeaker) flex and sub pba usb if still not working you have to change the sensor hub ic U4001 under the battery connector |
01-13-2017, 10:27 | #72 (permalink) |
Member: 1135025 Status: Offline Thanks Meter: 11 | it's mostly a burned capacitor somewhere on the board or water damage -> in case of cap, you have to find them yourself, look under the metal-shields near camera on both pba sides... if you cant see them so, only usefull solution is to look with thermal camera Last edited by cy8ex; 01-13-2017 at 10:33. |
The Following User Says Thank You to cy8ex For This Useful Post: |
