Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-30-2020, 07:39   #1 (permalink)
Member: 2222183
Thanks Meter: 48
Unhappy Samsung Note 4 Qualcomm HS-USB QDLoader 9008 ?
Samsung note 4 dead ( Qualcomm HS-USB QDLoader 9008 )
when i put in freezer for few mints after mobile working well for few time after got dead ( Qualcomm HS-USB QDLoader 9008 ) please tell me how to solve this problem.
Old 05-05-2020, 20:56   #2 (permalink)
helpful-man's Avatar
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
This is for Samsung note4 N910F:
For avoiding any more confusions , i have gathered all the links that are important .
These are the only files that you will need to debrick a n910f ,download them all and you are good to go :
This is the debrick.img :
https://mega.nz/#!PpVXga4R!AAAAAAAAA...AAAQ9oBW-CmsNk
The next is win32diskimager :
https://mega.nz/#!PtUDGArB!AAAAAAAAA...AAAOtL_pacxLGc
Qualcomm drivers: https://mega.nz/#!4lNliRYJ!3blyZgKug...2UjUIckEFhMRks
This is the recovery firmware for n910f (go to note4/511 and download each and every file ):
https://mega.nz/#F!QIMmFRIT!Ns3AM-n0FUoMqOOWUif9ng
This is the procedure:
-Open win32diskimager, load the debrick.img(3.74gb for n910f
[B] -Flash it on a blank sd card, the card should be completely formatted and should be in fat32 format.
[/B ]-Once done, put that sd card in your bricked device.
-Connect it to your pc.
-Hold the power button for at least 10 sec or try the download mode key trio.
-It should vibrate.
-If it doesnt, hold it in front of an air conditioner,
let it cool( this has been tested).
-If it still doesnt vibrates, remove the battery, hold the power button for 10sec and then insert the battery.
-Now again try to press power button.
>So, once it vibrates, leave it for around 5min.
-Then press the volume down key+power+home.
-It should boot in to download mode.
-Now you can flash stock rom or recovery firmware.
The Following User Says Thank You to helpful-man For This Useful Post:
Old 07-24-2020, 10:14   #3 (permalink)
Member: 1507433
What's the decrypt key
Old 07-27-2020, 09:26   #4 (permalink)
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
Here is new download link no need decrypt key
This is the recovery firmware for n910f (go to note4/ and download each and every file ):
Old 07-28-2020, 06:07   #5 (permalink)
Member: 1507433
Also need decrypt key sir every time I click your provided link
Old 08-01-2020, 16:38   #6 (permalink)
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
[QUOTE=jaymhar;14162746]Also need decrypt key sir every time I click your provided link
i uploaded again for you
Check please
https://mega.nz/folder/HsBEhI6D#hJ70ILRj-VplREaYcSKHvQ
The Following 2 Users Say Thank You to helpful-man For This Useful Post:
Page generated in 0.14222 seconds with 8 queries
