03-24-2004, 17:10 | #1 (permalink) |
Freak Poster Join Date: Nov 2002
Member: 17702 Status: Offline Thanks Meter: 0 | SGH-A800 dead due to bad charger Hi, Samsung SGH-A800. Phone was working fine. Someone connect a faulty samsung charger and try to charge it. From then and on the phone does not even power on at all. My guess is that some diode (or zener) **** up if the charger was supplying more than the required voltage. Anyone has seen this before? Any ideas as to what it can be? The peculiar thing is that if I put another (fully charged) A800 battery (from another A800 phone) still the phone does not power on. B.R. |
05-04-2004, 08:01 | #2 (permalink) | |
Freak Poster Join Date: Oct 2003 Location: GSM Center Ro ******** Age: 44
Member: 41900 Status: Offline Thanks Meter: 2 | Ltc1734 Quote:
Change LTC1734, you can buy it only from Linear tech directly from America.But first remove LTC 1734, and fuse nearby replaced if not OK, and try with a fully chargged accu.If doesn't work you have a dead phone, because you burned the processor. | |
05-21-2004, 21:12 | #3 (permalink) |
Junior Member Join Date: May 2004 Age: 41
Member: 66227 Status: Offline Thanks Meter: 0 | Hello! just connect it to power supply and set the current about 1.7 2.6 Am and voltage between leg 3 and 5 of the battery 2.6-4V because the chaging capositor was shotcircuted and you phone is short circuted so doing so is to restore the capositor.I have been solving several mobile with the same probleam. thanks. |
05-24-2004, 19:50 | #6 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | Hello all samsung cell phone using LTRG as a charger IC, the node on pin 2 must be 5.2 and pin 5 must be 4.22 which directly go to the + VBATT , if else, change LTRG. have fun mOLY |
help my samsung sgh-a800 dead after *2767*3855# i need flash repair or help please | barbarolc | VLSI, Conexant, Skyworks and Old Models | 1 | 01-17-2010 21:00 |
t68 dead due to 9V input | sakaz | Sony Ericsson Hardware Repair | 0 | 05-11-2008 21:17 |
K310a dead due to cruiser unlock | Tantech | Cruiser Suite | 1 | 03-22-2007 11:15 |
Nokia 6111 dead due to charging | TRABEL | Nokia Hardware & Hardware Repair | 12 | 02-25-2007 19:37 |
c 100 dead due to overcharging | gsmwiz | Samsung Hardware Repair | 0 | 02-12-2005 03:24 |
