01-25-2009, 09:36 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 665242 Status: Offline Thanks Meter: 16 | SAMSUNG SGH-G600 not turning on, only charging !! I have a Samsung SGH-G600 wich is not turning on , but when the charger is plugged in it charges fine on the screen. Any ideas? Thanks |
01-26-2009, 18:41 | #2 (permalink) |
Junior Member Join Date: Jan 2009 Location: GAWAIR.D.KHAN,DHAKA. Age: 32
Member: 954185 Status: Offline Sonork: [email protected] Thanks Meter: 10 | ok i think u should open the keypad sticker and make jumper with 3 battons.post the result. |
06-09-2010, 14:48 | #6 (permalink) |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | change top key board ribbon if problem is stil same then check top board connector if not then check pcb ribbon connector your phone must be water damadge good luck remember thanks button |
Nokia 6300 does not turn on,only blue side lights on. | cpu2007 | Nokia Hardware & Hardware Repair | 13 | 09-02-2014 06:17 |
Samsung G600 Not Turning on, Charges | NathanKent | Samsung Hardware Repair | 1 | 03-23-2010 11:36 |
5610D not turn on more charges | rmgoldner | Universalbox | 0 | 06-04-2009 17:38 |
d600 not power on..only charge | monte1987 | Samsung Hardware Repair | 0 | 11-01-2006 14:45 |
6230 can not turn on after charging | andesfong | Nokia Hardware & Hardware Repair | 2 | 10-31-2005 03:22 |
