Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Hardware Repair
Samsung Hardware Repair Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 10-17-2009, 15:04   #1 (permalink)
Member: 494572
Thanks Meter: 11
c170 blue lcd after change charge conecter 100% solutions
help i have c170 i tryed to change charge conector and display goes blue i tryed many lcd but no sucess and one had face this problem and solved plz??,
Old 10-17-2009, 15:39   #2 (permalink)
khan0001's Avatar
Member: 857488
Thanks Meter: 41
remove charging connector and then check
The Following User Says Thank You to khan0001 For This Useful Post:
Old 10-17-2009, 17:41   #3 (permalink)
Member: 741571
Thanks Meter: 43
run the software for it
Old 10-18-2009, 11:33   #4 (permalink)
Member: 494572
Thanks Meter: 11
ok
no way !!same probelm i removed charge conector and run sowtware all ok but always blue lcd (note: i can make call )any solution???
Old 06-30-2010, 04:29   #5 (permalink)
Member: 890328
Thanks Meter: 50
samsung c 170 blue display
facing the same problem,
i rcvd for replace the charging socket after replacing the set is dead
Old 07-01-2010, 11:41   #6 (permalink)
Member: 951177
Sonork: azib
Thanks Meter: 3
remove charging jack and fix it other one carfully mr panchami good luck
Old 07-02-2010, 10:19   #7 (permalink)
Member: 890328
Thanks Meter: 50
C 170
Thanks..................
only blue lcd after change sr8787 Chinese Models & Cloned Phones 1 04-19-2010 10:07
e250 no lcd after change charging connector abdel7650 Samsung Hardware Repair 6 09-01-2009 08:51
E250 white lcd after changing charging base alialjorany Samsung Hardware Repair 12 08-02-2009 07:05
E250 white lcd after changing charging base irfaN_vu Samsung Hardware Repair 7 04-13-2009 10:04
e250 white lcd after change charge socket ? TRABEL Samsung Hardware Repair 16 03-08-2009 23:05
Page generated in 0.15569 seconds with 9 queries
