04-26-2005, 00:38 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | X460 keyboard Have X460 which keys dont work,. Has a little waterdamage. Removed mic, volume keys but no luck. Anyone have service manual X460? Thanks Sjakie |
04-26-2005, 15:16 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | @sjakie: Give her z schemas for the keypad or at least photo for the keypad and I will send you the solution ! I haven(t a schemas or an X460 with me ! It's very easy ! try to out here the schemas of your keypad ! If you nead solution ! |
04-27-2005, 10:15 | #4 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Žilina Age: 45
Member: 62102 Status: Offline Thanks Meter: 167 | After water damage are broken varistors. I repaired one x450 /remove varistors from PCB/ and phone is working. Varistor are placed nearly key pads. See : http://forum.gsmhosting.com/vbb/showthread.php?t=191354 Last edited by pepik; 04-27-2005 at 21:33. |
The Following User Says Thank You to pepik For This Useful Post: |
07-26-2005, 09:14 | #8 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Estonia Age: 46
Member: 6208 Status: Offline Thanks Meter: 12 | If it does not work, try mine solution I tried also to remove those 5 varistors, but no result.... There's 5 more! Remove all 5 varistors, then all is OK |
The Following 3 Users Say Thank You to juht For This Useful Post: |
09-06-2005, 21:41 | #10 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | solved my problem by reflowing the sections marked with a circle after removed the 10 varistors that did not solve my problem. See attachments. Problem is that like an idiot i did not wait to see results but did 2 places at the same time. Please someone check me out which is which maybe we get to a definite solution. thanks al |
09-07-2005, 06:24 | #11 (permalink) |
Member: 6208 Status: Offline Thanks Meter: 12 | That means, you solved your problem without removing the varistors, just reflowing 2 areas? I think this were the 1st step i think... If reflowing does not help, then remove the varistors. But be carefull reflowing, samsung has main chips glued, and too hot air may kill the phone totally. This info goes to them, who has in future such problems :P |
09-08-2005, 17:29 | #12 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | @juht unluckily yes i did remove the varistors first and problem remained. I did not try to reflow first please anyone try reflowing first before removing varistors till we corner the solution. thanks al |
Keyboard up or Keyboard down ... | BaNgErS | Infinity-Box | 5 | 03-18-2008 13:06 |
samsunx x460 ?? | tekkelinc | SYSOL Platform | 20 | 01-19-2005 13:30 |
x460, x590, x120, lg5000, | cumana | Various CDMA/TDMA Cell Phones | 1 | 06-25-2004 04:21 |
x460, x590, x120, lg5000, | cumana | Samsung Flashers, Software, Firmware. | 0 | 06-21-2004 02:21 |
motorola keyboard helpmotorola talkabaut2 keyboard wont work | manijak | Motorola Hardware Repair | 1 | 07-10-2002 16:44 |
