Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
06-25-2008, 20:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | Any new solution for W850 display problem? I changed the flex cable as mostly known,I also rehot flash IC but negative Is there any new solution for this problem ? |
06-26-2008, 12:57 | #3 (permalink) |
Junior Member Join Date: Feb 2007 Location: kenya Age: 37
Member: 449561 Status: Offline Thanks Meter: 5 | Bro Dont Worry,i Have Been There.i Changed Everything But The **** Never Brought Positive Results. Do You Know Whats Screwing You?the Upper Keypand Plate.jst Change It And Everything Will Be Ok. 100%tested |
The Following 2 Users Say Thank You to anneva For This Useful Post: |
06-26-2008, 16:34 | #4 (permalink) |
Junior Member Join Date: Sep 2006
Member: 341790 Status: Offline Thanks Meter: 0 | anneva is right its the upper keypad and unfortunatly most of the w850s suffer from this problem fortunatly my keypad is still working and the phone is 1 and a bit years old, the only thing that annoys me and it sounds like my phone is the only one thats done this is the orange rythem light is broken! :'( and when i get any spare money i need to buy another keypad :P |
03-09-2009, 21:43 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Kuala Lumpur Age: 43
Member: 287805 Status: Offline Thanks Meter: 132 | before i allready solve many w850 lcd become white. or blinking or no light with changing the flex and the upper keypad board. now i have 1 w850 that i allready change the flex and the upper keypad board.. but the lcd light still dont have... allready change too many of flex and the upper keypad board original still no luck.. any solutions for it...... please... |
06-05-2010, 23:28 | #7 (permalink) |
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | 1st thing the easiest one, is flash your phone properly or else there will be no results,if problem presists,do as i did: I replaced the upper keypad plate and it worked like charm,if problem presists change also LCD i faced it once. if problem presists change upper plate and lcd and flash the phone properly if problem presists put the phone under some truck or under a hammer H3 and all your problems will disappear, hhh just kiding |
100% working solution for w850 flash ok white or blinking white display | dreameye | Sony Ericsson Hardware Repair | 0 | 06-11-2009 14:49 |
W850 Display problems | sandro123 | Sony Ericsson Hardware Repair | 9 | 10-28-2007 21:29 |
Any New Solution For Imei Corrupt | rajus | Nokia Hardware & Hardware Repair | 1 | 10-26-2007 05:54 |
Any new solution for K700 flash? | woodschang | Sony Ericsson | 0 | 11-13-2004 10:03 |
