Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-11-2001, 22:10   #1 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Arrow SONY J5 _ NO SOUND
Hi m8s<br />i have sony j5 with no ring sound,<br />it seems handsfree capsule is disconnected,<br />i checked it , no result!<br />any solution?
Old 12-11-2001, 22:42   #2 (permalink)
Member: 6537
Post
hi arc
replace multiactor,this device is combined electrodynamic vibtator excitor.<br />you should be ok once you change this.is common fault on j5.
best regards<br />jinn
Old 12-21-2001, 21:39   #3 (permalink)
t68
Member: 6995
Post
Easier than that open the phone and pull the legs out on the speaker earpiece very common fault
Old 12-21-2001, 23:03   #4 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Post
@JINN:<br />thanks, but could u explain more?<br />what is multiactor<br />I have no spare part for J5
@t68<br />I have sound, I can hear from earphone,<br />I mean that my J5 doesn't RING,
Old 12-22-2001, 10:26   #5 (permalink)
Member: 7767
Thanks Meter: 3
Post
Remove buzzer from ribbon. Check resistance on buzzer. If nothing, then replace it. Same problem was in my phone.
Old 12-23-2001, 15:35   #6 (permalink)
Member: 7892
Post
IS the buzzer on a flex foil?
If so check the foil with a multimeter for broken parts
Old 12-28-2001, 21:39   #7 (permalink)
ARC
ARC's Avatar
Member: 5019
Sonork: 100.110196
Thanks Meter: 69
Post
thanks to all for replies<br />i will try it
Old 12-29-2001, 05:43   #8 (permalink)
sat
Member: 5764
Thanks Meter: 2
Post
I got two phones with this fault. Buzzer itself is not working. I have no spare parts for this phone, where to get buzzer to get it work on this phone? Maybe from some other phone?
Old 12-29-2001, 16:44   #9 (permalink)
Member: 2461
Thanks Meter: 22
Post
I had Brand new J6<br />And the sound went off..!!<br />No Keypad sound/ Ringtones /even no sound at switch on/off<br />Sound was up full in the menu ?<br />I did a factory reset<br />And the sound then worked perfectly <img src="biggrin.gif" border="0">
Old 12-30-2001, 20:09   #10 (permalink)
themobileking's Avatar
Member: 5072
Thanks Meter: 91
Post
The Ringer /Speaker is faulty and has to be replaced.
since it is not yet available you will have to try /experiment with the same from other phones.
Rgds <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> <img src="cool.gif" border="0"> <img src="cool.gif" border="0">
Old 01-03-2002, 00:16   #11 (permalink)
Member: 6537
Post
As mentioned before j series phones have a separate multiactor device,which makes the phone ring.sony has identified that this is a common fault on j series phones.<br />if you need i can supply you multiactor for £20 uk pounds plus £5 extra for post and packing.<br />sorry cant send for free.
br
jinn
J5 no Network no Sound????? masterross Sony 2 08-19-2003 19:46
Sony J5 / no ring no vibra pali Sony Ericsson Hardware Repair 7 03-08-2003 17:04
Sony Z-5 no sound only noise? NSerN Sony Ericsson Hardware Repair 0 01-17-2003 12:47
Sony Z5 _ No Network! ARC Sony Ericsson Hardware Repair 4 01-08-2003 16:24
Sony Z5 _ No Mic_no Speaker ARC Sony Ericsson Hardware Repair 0 10-02-2002 22:50
Page generated in 0.16702 seconds with 9 queries
