Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
07-04-2009, 13:35 | #229 (permalink) |
Junior Member Join Date: Feb 2009
Member: 983253 Status: Offline Thanks Meter: 0 | hi sir i have a w880 no display is coming i had upgrade the software but still same problem any diagram or any jumper is there to solve it sir just geeting display blue blank try to change the display but still same problem |
07-04-2009, 13:36 | #230 (permalink) |
Member: 983253 Status: Offline Thanks Meter: 0 | display problem model w880 hi sir i have a w880 no display is coming i had upgrade the software but still same problem any diagram or any jumper is there to solve it sir just greeting display blue blank try to change the display but still same problem |
07-04-2009, 16:43 | #232 (permalink) |
No Life Poster Join Date: Mar 2008 Location: London
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | hi every one, i got a k320 which was orignaly on vodafone uk and some one tried to unlock it but i dont know what went wrong and now the phone says insert correct sim even for vodaphone as well. it tried to unlock it with test sim but even when i put the test sim it says insert correct sim. here is the logs for identifying the phone: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:101100000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601721027 CERT:RED FLASH CID:50 COLOR:RED Model (from GDFS):K320i Brand:Generic MAPP CXC article: R4GC012 prgCXC1250682_GENERIC_MA MAPP CXC version: R4GC012 Language Package: CENT_EUROPE CDA article: CDA102727/2 CDA version: R2A Default article: cxc1250690 Default version: R4GC012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 17 secs. is it that the phone is 5 lock and if so then how much logs it takes to repair it |
07-04-2009, 16:48 | #233 (permalink) |
Member: 722656 Status: Offline Sonork: 100.1584918 Thanks Meter: 294 | hi every one, i got a k320 which was originally on vodafone uk and some one tried to unlock it but i dont know what went wrong and now the phone says insert correct sim even for vodaphone as well. it tried to unlock it with test sim but even when i put the test sim it says insert correct sim. here is the logs for identifying the phone: SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:101100000000000 ChipID:8040,EMP protocol:0301 NEW SECURITY (MARITA RESPIN) PHONE PHONE STATE: "RETAIL" FLASH CID: 0050 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:50 PAF:1 IMEI:35670601721027 CERT:RED FLASH CID:50 COLOR:RED Model (from GDFS):K320i Brand:Generic MAPP CXC article: R4GC012 prgCXC1250682_GENERIC_MA MAPP CXC version: R4GC012 Language Package: CENT_EUROPE CDA article: CDA102727/2 CDA version: R2A Default article: cxc1250690 Default version: R4GC012 PROVIDER: 000-00 SIMLOCKS NOT DETECTED USERCODE:0000 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 17 secs. is it that the phone is 5 lock and if so then how much logs it takes to repair it |
..::Get ALL BB5 Problems I Solved In Only 1 hours::.. | 786786 | Nokia Repair Guide and FAQ | 4179 | 03-28-2014 18:56 |
.....::::: Get Me Ur Problem I Solved In Only 6 Hours::::.... | 786786 | Motorola Hardware Repair | 315 | 06-08-2013 17:55 |
..::Get ALL DCT4 Problems I Solved In Only 1 hours::.. | RIZWANJAT | Nokia Hardware & Hardware Repair | 5 | 11-26-2010 18:12 |
Post urs problem here solves in 24 hrs by Javajohn | Javajohn | Nokia Hardware & Hardware Repair | 92 | 06-17-2006 07:43 |
problem and solve in SL45i | Ahmed Jundy | x1x to x45/x50 | 6 | 12-31-2003 00:42 |
