Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 05-09-2004, 06:11   #1 (permalink)
genocite's Avatar
Member: 5379
p900 can't charging,
got p900 which can't charge, if resistance measured between the battery + and - legs, shows a bit of resistance leakage, if the power supply 3014/2c was removed, the resistance leakage was gone, if the pa was removed, the resistance leakage decreased until a very small value, also already changing all small part including charging ic around all the power supply module, any idea which part or section maybe defective ?
thanks a lot for any input
regards
Old 05-10-2004, 07:58   #2 (permalink)
genocite's Avatar
Member: 5379
problem solve, thanks
Old 06-16-2004, 15:23   #3 (permalink)
eko
eko's Avatar
Member: 30098
Thanks Meter: 29
Got a p900, with charging problem, tried all the above , but still not charging any suggestions as to solving this problem please
Old 10-16-2004, 15:31   #4 (permalink)
raman_mlp's Avatar
Member: 14442
Thanks Meter: 4
@genocite..
how u solve it ??
Old 12-13-2004, 13:31   #5 (permalink)
Member: 77254
Thanks Meter: 9
I have problem on P900, when I charge the battery till full and switch it on. The battery indicating it's empty but the led is green. The I try to make a call, the low battery warning will appear. I replace the battery with new one, but the problem persist. Any idea how to fix it, and which part is fault?
Old 12-25-2004, 20:51   #6 (permalink)
GSM Deals's Avatar
Member: 3936
Thanks Meter: 237
just check battery connector soldered side may be bad soldering resolved problem like yours this way
regards
Old 04-21-2005, 08:04   #7 (permalink)
malta's Avatar
Member: 27289
Thanks Meter: 24
can you tellme what is the problem since i have p910i with charging pins short circuit
Old 05-30-2005, 12:59   #8 (permalink)
Member: 52430
Thanks Meter: 3
hi u just say u solve this problem,
how? let's share
Old 05-30-2005, 13:09   #9 (permalink)
malta's Avatar
Member: 27289
Thanks Meter: 24
There`s A G Named Transistoron Top Pf The Board Just Change It
The Following User Says Thank You to malta For This Useful Post:
Old 08-08-2005, 16:30   #10 (permalink)
SIXTUS's Avatar
Member: 69727
Thanks Meter: 49
P900 discharges battery
where is the A G transistor you are talking about... where is it located?
Old 08-09-2005, 14:42   #11 (permalink)
malta's Avatar
Member: 27289
Thanks Meter: 24
up near the led indicator
Old 08-11-2005, 09:40   #12 (permalink)
SIXTUS's Avatar
Member: 69727
Thanks Meter: 49
ok i will try and post result,.......
Old 11-28-2005, 07:35   #13 (permalink)
Member: 203604
what is the part number of the A G transistor?
I don't have the schematic for the P900. Can someone who has it send it to me. What is the part number of the A G transistor? If you could give me the some description of the transistor, it would be helpful. thanks a lot.
Old 03-25-2007, 22:39   #14 (permalink)
Member: 18369
Thanks Meter: 3
Measure between the legs on the transistor labeled 6F near blutooth led.
On mine P910i it was only 10 ohms between 2 legs so I exchanged it with a transistor from a old R310s board it is located close to the backup battery on R310s.
Look for the label "6F".
Best regards Daniel
Old 03-26-2007, 03:45   #15 (permalink)
Member: 388978
Thanks Meter: 88
best solution:
1: check system connector
2: Replaced N701 (IC near system connector) (main cause)
3: check some capacitor (round the N701)
4: check IC power.
my p900 can't use bluetooth ! please help me vivas1437 UFS2 + UFS3-Tornadoflasher 0 09-23-2005 14:25
P900 not charging Cat10 Sony Ericsson Hardware Repair 4 04-21-2005 08:40
P900 can't turn on unlocker@la Cruiser Suite 3 01-26-2005 09:27
P900 not charge Angello Sony Ericsson Hardware Repair 1 01-16-2005 18:28
P900 can't pass through the power menu!! How? xms_nard Sony Ericsson 6 12-12-2004 14:14
Page generated in 0.21473 seconds with 9 queries
