Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
12-31-2007, 14:46 | #2 (permalink) |
Freak Poster Join Date: Aug 2006
Member: 340774 Status: Offline Thanks Meter: 164 | try to chk its keypad track or change the keypad is d best way.... if ur problem solved then its fine if nt then change its ribbon wire ur problem will solved 100%%%%%%%..... b,coz i got same prob and i change ribbon wire |
The Following User Says Thank You to vinkle For This Useful Post: |
10-16-2008, 19:19 | #5 (permalink) |
Freak Poster Join Date: Feb 2002 Location: MOBILE
Member: 9491 Status: Offline Thanks Meter: 14 | change the micro switchs on the lcd board i.e. the side push buttons. resolder the key pad jack on the main board |
The Following User Says Thank You to SATISH For This Useful Post: |
07-22-2009, 15:06 | #7 (permalink) |
No Life Poster Join Date: Oct 2005 Location: gavni
Member: 188646 Status: Offline Thanks Meter: 76 | hi i have w550 keypad problem i change keypad ic but still some problem these key not working 4 6 # c ok back ok not working plz help me wajo |
The Following User Says Thank You to gsm-iran For This Useful Post: |
6700c keypad problem | luyanda | Nokia Hardware & Hardware Repair | 20 | 04-09-2014 10:16 |
w550 keypad problem | faju | Sony Ericsson Hardware Repair | 5 | 11-15-2008 08:41 |
w550 Backlight n Keypad problem | gct | HWK | 4 | 02-22-2008 23:00 |
w550 keypads problem | almobilelink | Sony Ericsson Hardware Repair | 5 | 07-11-2007 08:14 |
W550 keypad fault | bleck | Sony Ericsson Hardware Repair | 4 | 08-19-2006 18:57 |
