Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson Hardware Repair
Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones.
Old 12-31-2007, 09:01   #1 (permalink)
Member: 667192
Thanks Meter: 2
Cool W550 keypad problem
Hi my 0 , 5 and ok key is not working , so if anybody know the reason pls help me.
The Following 2 Users Say Thank You to mobiledada For This Useful Post:
Old 12-31-2007, 14:46   #2 (permalink)
Member: 340774
Thanks Meter: 164
try to chk its keypad track or change the keypad is d best way.... if ur problem solved then its fine if nt then change its ribbon wire ur problem will solved 100%%%%%%%..... b,coz i got same prob and i change ribbon wire
The Following User Says Thank You to vinkle For This Useful Post:
Old 03-25-2008, 15:58   #3 (permalink)
sulai2k's Avatar
Member: 311025
Sonork: 100.1607375
Thanks Meter: 171
u r set is power switch sort
u check first
The Following User Says Thank You to sulai2k For This Useful Post:
Old 03-25-2008, 16:22   #4 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 831
sulai2k reply check it?
search befor ask.
try this . http:///vbb/search...rchid=34011395
wbr
The Following User Says Thank You to baraka42 For This Useful Post:
Old 10-16-2008, 19:19   #5 (permalink)
Member: 9491
Thanks Meter: 14
change the micro switchs on the lcd board i.e. the side push buttons.
resolder the key pad jack on the main board
The Following User Says Thank You to SATISH For This Useful Post:
Old 10-17-2008, 07:34   #6 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
chang the lcd board.........
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 07-22-2009, 15:06   #7 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hi
i have w550 keypad problem i change keypad ic but still some problem these key not working 4 6 # c ok back ok not working plz help me
wajo
The Following User Says Thank You to gsm-iran For This Useful Post:
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
w550 keypad problem faju Sony Ericsson Hardware Repair 5 11-15-2008 08:41
w550 Backlight n Keypad problem gct HWK 4 02-22-2008 23:00
w550 keypads problem almobilelink Sony Ericsson Hardware Repair 5 07-11-2007 08:14
W550 keypad fault bleck Sony Ericsson Hardware Repair 4 08-19-2006 18:57
Page generated in 0.13827 seconds with 9 queries
