Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
11-03-2009, 14:59 | #1 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 655261 Status: Offline Thanks Meter: 46 | help !!! K850 die !!!! when I press power on power ic chip verry hot ...and no power on .. I chang power ic ... but still same can you help me thanks |
11-06-2009, 08:07 | #3 (permalink) |
Banned Join Date: Oct 2009 Location: Inside Digital GSM Age: 35
Member: 1149774 Status: Offline Sonork: 0313-9541047 Thanks Meter: 1,163 | bro just remove power ic than chk press power b & chk ur pcb is gone heat up or not then post result if pcb i not going to heat up then 100% fault in ur pwr ic if not then chk more shot circut.... Thanks |
The Following User Says Thank You to gsm_3gn For This Useful Post: |
11-13-2009, 05:14 | #6 (permalink) |
Freak Poster Join Date: Feb 2008 Location: secret
Member: 711270 Status: Offline Thanks Meter: 30 | comfirm u change a new,good 1 power ic ???or u check light coil ???some it will effect power ic hot too..if u change power ic and without programme bck imei the phone oso can use ... |
need help k850 | wadda7e | Sony Ericsson Hardware Repair | 0 | 02-21-2010 17:02 |
need help k850 | skywong | Sony Ericsson Hardware Repair | 3 | 02-04-2010 15:59 |
pls help k850 | skywong | Sony Ericsson Hardware Repair | 5 | 01-26-2010 11:03 |
help k850 flashing | alvis168 | Universalbox | 2 | 11-15-2008 12:22 |
Help!!! GD93 DIED!!! | Jo sptel | Panasonic | 2 | 03-12-2002 00:50 |
