Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
10-10-2008, 09:03 | #16 (permalink) |
Freak Poster Join Date: Feb 2008 Location: CITY OF PINES
Member: 695023 Status: Offline Thanks Meter: 53 | open the phone.... short the backup battery inside just for 3-5 seconds.... then connect to any device....if connected your phone is alive no need to flash... tested many times.... |
10-13-2008, 21:16 | #18 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | 1) connect phone with dcu-60 cable {press and hold "c"}.....If not connect... 2)change the baudrate with dcu-60 cable {press and hold "c"}.....If not connect... 3)connect phone with dcu-60 cable {press and hold "2+5"}...If not connect... 4)change the baudrate with dcu-60 cable {press and hold "2+5"}..If not connect... 5)use com cable with ufs...or something fighter or.....Also try with changing baudrate....If not connect... 6)check the system connector...try to clean it...and also check the pcb....If not connect... 7)try other tricks..like "shorting battery connector"...and giving "slightly heavy voltage in battery connector"...with your own risk...If not connect... 8)then.....Think about time or money! |
12-04-2008, 02:08 | #21 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Philippines
Member: 218941 Status: Offline Thanks Meter: 1,801 | 1) connect phone with dcu-60 cable {press and hold "c"}.....If not connect... 2)change the baudrate with dcu-60 cable {press and hold "c"}.....If not connect... 3)connect phone with dcu-60 cable {press and hold "2+5"}...If not connect... 4)change the baudrate with dcu-60 cable {press and hold "2+5"}..If not connect... 5)use com cable with ufs...or something fighter or.....Also try with changing baudrate....If not connect... 6)check the system connector...try to clean it...and also check the pcb....If not connect... 7)try other tricks..like "shorting battery connector"...and giving "slightly heavy voltage in battery connector"...with your own risk...If not connect... 8)CHARGING PROBLEM OPEN THE PHONE |
12-07-2008, 09:59 | #22 (permalink) |
Insane Poster Join Date: Dec 2006
Member: 404765 Status: Offline Thanks Meter: 19 | try this and reply any sony erricson try to find the diode which is in line vt BSI try to disconnect it or heat vt element ..... and d set goes for boot (this is tried for those blinking red light set .. I have tried in 3 sets it worked ) |
06-28-2010, 22:59 | #23 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1318413 Status: Offline Sonork: infos pour tous Thanks Meter: 0 | k610 died not boot boot stop in only 14% and tell UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 76766 HID: 20AC850041600093 HWK: A1.04-PRO1 Licence: True, 00:10 MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 Prologue Error 2: 45 61 54 MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 Prologue Error 2: 45 61 54 |
06-28-2010, 23:04 | #24 (permalink) |
Member: 1318413 Status: Offline Sonork: infos pour tous Thanks Meter: 0 | UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., S/n: 76766 HID: 20AC850041600093 HWK: A1.04-PRO1 Licence: True, 00:10 k610 not boot stop in14% only tell this message MCU_ID : 99000301FFFFFFFF S_BAUD : 115200 Prologue Error 2: 45 61 54 help me please |
About Solution for dead boot on Zxxx... | hallo | UST Pro II | 7 | 09-24-2007 16:24 |
No EXE only for MTBOX SE DB2020 2.7?? 75MB AGAIN!! So BIG!! :( | bestncheap | MT-BOX | 1 | 08-17-2007 22:51 |
how much credit need for customizing se db2020 phones | speedstarrr | Universalbox | 2 | 07-19-2007 08:49 |
Receipe for unlocking SE DB2020 | Zwed888 | Cruiser Suite | 0 | 08-14-2006 07:44 |
