Sony z2 only red light flashing solution. Make this jumper tested 100%. https://drive.google.com/file/d/0Bwr...w?usp=drivesdk |
can you pls repost picture? wbr |
tnx bro...i have 2 xperia z2 redlight only...i apply the jumper now its working,,, |
Know and let people know this is called helpful koukou أرسلت من C6903 بإستخدام تاباتلك |
hello, can you please help? same problem, only red light, 3 red blinks when trying to turn on. first i tried other software solutions from another forum, no chance. then i tried hardware solutions. with the battery disconnected, and plugged the phone in charger. it showed on screen battery icon and charging for a few seconds and then it restarted. and nothing more. then i tried your solution but i think i made a mistake. the phone will not blink 3 times red when battery connected and trying power button like before. and with battery disconnected, charger connected, lcd lights up but nothing is shown on screen now. i don't know what to do |
Can you provide me a pictures of motherboard and phone when it led up. Regards.AHMED KOUKOU أرسلت من C6903 بإستخدام تاباتلك |
Oops,disconnect battery tell you post the pictures. Do this fast as fast not damage the phone because it seems it is a short between gnd and vbat. أرسلت من C6903 بإستخدام تاباتلك |
Hello, Upload pictures of your motherboard with jumper. Your phone now have a short circuit remove the jumper after take pictures. Regards, AHMED KOUKOU أرسلت من C6903 بإستخدام تاباتلك |
sorry for bad image. this is the best i could take with another phone at first try i didn't solder only the big contact, there was no connection with the small capacitor. i had the connection redone by a professional guy and this is how it looks now phone is not starting, when plugged in computer, pc companion recognizes the phone and gives me a message to disconnect and power on the phone but that doesn't help. also, when holding power and volume up, there is no reset, it does not vibrate 3 times http://imgur.com/RqMwwcd i'm not sure why the image is not loading, here is the link http://imgur.com/RqMwwcd |
<< more info >> when plugged in the computer, nothing happens for about 1 minute, after that the lcd backlight lights up, but without image and a blink of red led lights up behind the speaker. after this the pc tries to install MTP USB Device, another 3-4 seconds and the phone restarts and the process begins again... lcd backlight lighting up, no image on display, red led, driver install in pc the only way i can stop this process is to unplug the battery connector from the motherboard |
It maybe battery voltage is too low. أرسلت من C6903 بإستخدام تاباتلك |
now it has been about 1 hour charging, still no response. with battery disconnected from motherboard i tried to flash a ftf file and flashtool did it's job very well. so the software can be changed. but still no response when trying to power on |
You have a power supply.? أرسلت من C6903 بإستخدام تاباتلك |
