Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
08-21-2008, 18:56 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2007 Location: UniversalBox Age: 13
Member: 644786 Status: Offline Thanks Meter: 2,166 | Repair Information Document Listing By Sonyericsson Problem Buzzing or Crackling sound heard from the receiver during call. The problem is also caused when the charger is inserted to the phone when placing call. Root Cause The Root Cause of the issue is from SMT production, during the screen printing of solder paste not enough has been applied to Mic PCBA pads, therefore causing dry solder joints that creates the buzzing sound under certain conditions. Unclear of how many affected units due to unclear production weeks are affected, units we have received so far were produced WK816 Solution Remove B3100 Mic add solder to PCBA Mic pads then re-solder B3100 Mic. Retest the Mic and verify if its working from service menu tests and live call. SMT production have been informed to tighten there process for screen printing. Reference number: 16491-71759 Created: 2008-08-21 |
The Following User Says Thank You to SEMCSEC For This Useful Post: |
08-22-2008, 11:53 | #2 (permalink) |
Member: 644786 Status: Offline Thanks Meter: 2,166 | W380/Z555, Display Problem UPDATED This document is applicable for W380 and Z555 Introduction If a customer returns a phone (W380 or Z555) due to a problem with the main display, one possible cause is a damaged main LCD flex that is shorting against the metal frame of the upper front cover. Solution In the process of addressing the inner display problem, if the step is reached in the troubleshooting procedure to replace the Upper Front Cover assembly (This assembly contains the inner display) add the Protective Plate Tape to eliminate the risk of the LCD flex shorting to the metal frame. NOTE! If the upper portion of the phone is disassembled for any reason, you should check for the presence of the Protective Plate Tape. If Protective Plate Tape is not present it should be added. Even if the LCD flex does not appear damaged, add the Protective Plate Tape to eliminate the risk of the problem arising later and causing a re-return. Refer to the Mechanical Working Instructions of each model, for detailed instructions on proper placement of the Protective Plate Tape for that model. Reference number: 16519-71664 Created: 2008-08-21 |
The Following 2 Users Say Thank You to SEMCSEC For This Useful Post: |
08-22-2008, 11:55 | #3 (permalink) |
Member: 644786 Status: Offline Thanks Meter: 2,166 | New SERP Release 1.9.06 This document is applicable for SERP Users Introduction A new release of SERP is available for download from CSPN Reason for change • Added support for the following new products: C902c, W760c, G700c, R300i, R300a, Z250a, W980, TM506 • Added support for the following new TAC’s: 35651402 (W580), 35653202 (W200a), 35379802 (C902c), 35441202 (W760c), 35706702 (W760i), 35648302 (W760i), 35648302 (W760i), 35551802 (Z320i/Z320c), 35389002 (G700c), 35452502 (R300i), 35457202 (R300a), 35552002 (Z250i/Z258c), 35934701 (Z250a), 35623702 (W350a), 35535302 (W980), 35726402 (W580im), 35739202 (W910i), 35726602 (W580), 35726502 (W580), 35726202 (TM506), 35714902 (C902), 35507602 (TM506), 35698302 (TM506) Fixed a SW bug in the Z250 and Z320 GNG routines. Comments Please download and use. This information is provided by: Customer Services Sony Ericsson Mobile Communications AB Reference number: 16485-71757 Created: 2008-08-21 |
08-22-2008, 12:11 | #4 (permalink) |
Member: 644786 Status: Offline Thanks Meter: 2,166 | SI – Update “Use DCU-65 instead of DCU-60” Affected products: DCU-60 Description: This SI is an update/clarification on the SI 16248-69241. It has been discovered that the DCU-60 is not really speed compliant. This may effect performance and potential fails while flashing a product with Emma. To be on the safe side and simplify the message, it is recommended that no matter which product platform, (that use USB) Service Centres should ONLY use the DCU-65 cable (RPM13112). DCU-65 has got 2 "big bubbles" on the physical cable. These "bubbles" are de-coupling devices to remove interference. The DCU-65 cables are a bit shorter than the DCU-60 cables. |
09-04-2009, 21:49 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 50
Member: 256461 Status: Offline Sonork: 100.1608049 Thanks Meter: 90 | Quote:
pls give the link for this useful information sajidmirza | |
09-10-2009, 01:37 | #6 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Tunisia Age: 43
Member: 93850 Status: Offline Thanks Meter: 48 | Quote:
after changing flex and display problem not solved. solution is to remove the small lcd br! | |
The Following User Says Thank You to electrosoft For This Useful Post: |
Software Document Listing By SonyEricsson | SEMCSEC | Sony Ericsson | 20 | 04-29-2017 10:00 |
E8 Bootloader Compatibility & Repair Information | green bird | MSS Box II | 12 | 09-10-2011 00:05 |
Repair Information System Software | a4tech | Universal GSM Software | 6 | 08-20-2006 03:08 |
repair information for Sam E800 | gsm40 | Samsung Hardware Repair | 0 | 11-05-2004 14:44 |
Document listing for every GSM Phone made to date | jbes | Wanted Products | 2 | 05-07-2004 10:20 |
