Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
04-27-2010, 20:27 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Slovakia Age: 43
Member: 13922 Status: Offline Thanks Meter: 334 | Xperia X10 - not charging I received brand new Xperia X10 (master piece) but after 2 charging process, it can't recognize any connected charger anymore. Also cable connection with PC is not working. Is there any possibility to solve it? I suppose it can be only FUSE or something else, but without servise manual is hard to find out rootcause of my problem. |
The Following User Says Thank You to SPUnlock_SK For This Useful Post: |
07-22-2010, 19:02 | #3 (permalink) |
Junior Member Join Date: Dec 2005
Member: 213003 Status: Offline Thanks Meter: 2 | i also have the same problem but when i changed connector i saw that board prints r damaged cause by fall down while it was on charging so now i am looking for schematic or charging ways so that i can put jumper and get my mobile working |
The Following User Says Thank You to sultan007 For This Useful Post: |
09-21-2010, 13:21 | #5 (permalink) |
Insane Poster Join Date: Feb 2005 Location: flashgsm.ro
Member: 119482 Status: Offline Thanks Meter: 4 | Hello I had the same problem and I repair it and the connector leaved the board exfoliated. I managed to remade 4 connections on the board + 5V ,ground ,data- and data+, I want to attach a picture but I can not do that I do not know why.The initial problem was that Data+ was interuppted but when I heat the connector out of the board the board was exfoliated so I had to remade all four connections. 2 of the data + and data - on the other side of the board. |
The Following User Says Thank You to dadustar For This Useful Post: |
09-23-2010, 06:58 | #7 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: BIRMINGHAM UNITED KINGDOM Age: 34
Member: 488632 Status: Offline Thanks Meter: 391 | hello sir Quote:
plz post a jumper picture thanks in advance | |
09-23-2010, 07:00 | #8 (permalink) | |
Member: 488632 Status: Offline Thanks Meter: 391 | and Quote:
i can take a picture of phone board | |
04-22-2011, 21:32 | #11 (permalink) |
Insane Poster Join Date: Oct 2010 Location: Everywhere
Member: 1413143 Status: Offline Thanks Meter: 15 | X10 Charging Schematic X10 Charging + USB solution image X10 Charging IC way Use search... You need 5V - 650(700)mA charger tested by me if you use 500mA charger... you will get the led light on.... but it will not charge |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
Nokia 5110 - "SIMcard not accepted". | Kond | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2000 22:46 |
winlock wintesla m2bus do not work | Bigbrothers2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-26-2000 14:31 |
