Sony Ericsson Hardware Repair Post here your Hardware Repairing Hints or Problems with SonyEricsson and Sony Phones. |
03-31-2007, 02:15 | #1 (permalink) |
Junior Member Join Date: Mar 2007
Member: 462889 Status: Offline Thanks Meter: 1 | Z530i Help ****** all OK **** CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:125 Will flash 125 blocks... SSW loading returns:0 Searching... Firmware OTP check determined. Setting up GDFS... IMEI MISMATCH !!!! POSSIBLE STOLEN PHONE !!!!! ORIGINAL IMEI:35285001850834 CURRENT IMEI:35928400498160 Clearing total time... Writing simlocks... ALL UNLOCK/LOCK CODES SET TO "45414082" Signing... control keys complete. full sig complete. CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2_V26 Switching speed.... loader startup: executed Can't get packet properties. wrong response, break. loader fs startup failed, that is fatal Elapsed:1077 secs. please help |
03-31-2007, 04:36 | #3 (permalink) |
Member: 462889 Status: Offline Thanks Meter: 1 | thank you but ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R6BA030_GXC1250454_GENERIC_MU Restore from:R6BA030_GXC1250454_GENERIC_MU can't open file "G:\MOBILE2\setool2g.exe\rest\R6BA030_GXC1250454_G ENERIC_MU" writing G:\z530\z530_gdfs_in_ssw_format.ssw CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:16 Will flash 16 blocks... SSW loading returns:0 writing G:\z530\r6ac006_m_east_n_afr_fs.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:125 Will flash 125 blocks... SSW loading returns:0 writing G:\z530\r6ac001_CXC1250454_GENERIC_MU.ssw.cry CURRENT FLASH FILE CID:49 SSW uses dynamic hash, dynamic hash len is:328 Will flash 328 blocks... SSW loading returns:0 Searching... Firmware OTP check determined. Setting up GDFS... Error while reading critical data Elapsed:568 secs. merci |
04-02-2007, 23:30 | #4 (permalink) |
Member: 462889 Status: Offline Thanks Meter: 1 | please help i've tried writing gdfs in ssw format.. Error in :executing CS FS startup... *** REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS 'TESTPOINT OK' Open COM port OK ChipID:8040,EMP protocol:0301 PHONE IS RED RETAIL PRODUCT FLASH CID detected:49 Speed:921600 Trying to launch embedded bootloader... Embedded flashloader: COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2 Flash ID check:897E Flash props sent ok FOUND: R6AC001_CXC1250454_GENERIC_MU Restore from:R6AC001_CXC1250454_GENERIC_MU writing G:\z530\z530_gdfs_in_ssw_format.ssw CURRENT FLASH FILE CID:254 SSW uses dynamic hash, dynamic hash len is:32 Will flash 32 blocks... SSW loading returns:0 CSloader version: COMPACT_SEMC_FS_LOADER_SETOOL2_V26 Switching speed.... loader startup: executed loader filesystem startup: executed csloader refused to start GDFS services,error is:29 loader GDFS startup failed, that is fatal Elapsed:116 secs. Please help rgds; |
The Following User Says Thank You to GSM Electronic For This Useful Post: |
help me z530i | azzouggsm | SETool2 | 3 | 03-29-2010 14:46 |
Z530i help urjent | Shantobhai | Sony Ericsson Hardware Repair | 1 | 09-01-2008 10:57 |
z530i help | muratcell | Cruiser Suite | 2 | 02-13-2007 09:49 |
Z530i Cruiser team help now | Irfangk786 | Cruiser Suite | 3 | 10-06-2006 21:00 |
Help on Z530i | fahd-gsm | Cruiser Suite | 1 | 06-20-2006 15:57 |
