11-02-2004, 06:18 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | a920 unlock problem i have a920. i can't unlock with umimoto. i'm using solution for lejiga. Your problem is caused by ignorance. You have to understand how Motorola phone comunicate with PC via USB bus. As you may already know, unlock procedure for A Series phone s is diferent than for V or C series. There are two steps, each of them need separate drivers to be installed. 1. Download unimoto 2.18 2. Power on the phone in normal mode, and wait till windows install "Motorola USB modem" 3. Run unimoto 2.18 and click "install drivers" button, wait till windows install all 5 new devices under motorola part in device manager. 4. Check in device manager if all is ok - if yes, you can start with unlocking. 5. Put phone in bootloader mode (for A920 change to BP bus) and click "unlock" 6. Software will ask you to power on the phone (for A920 it will restart phone automaticaly) 7. You'll see "waiting" then, after windows initialize drivers "witing 4 seconds" then, "connected to phone please wait". If you have all drivers PREINSTALLED corectly, you'll have "unlocked ok" in few seconds. - Possible problems: 1. You need to use SAME USB port each time for motorola phones. Otherwise, you'll have "motorola USB modem #X " where "X" is number of "modems " installed each time you change USB port. In this case, open Control Panel, Modems, with phone connected, and delete all motorola USB modems from it, in order to install it corectlly. 2. Battery has to be FULLY charged, 3. Brain should be working, at least in "safe mode" -))))))) I hope this will clear the situation. Do not ask me these questions i have answered here via mail, icq or sonork, i am sorry, but i have no time to teach all customers how to use windows and install drivers. For unimoto 2.18, and diferent types of drivers, please visit www.unimoto.net and www.unimoto.net/forum Thanks. please help me. i'm enter test mode i can't see BP bus mode only see ce-bus mode. how change to ce-bus to bp-bus. please help me thank you for help |
Samsung Jet S800 Unlock problem | javakiller | Z3X-Team Products | 8 | 05-15-2010 12:14 |
a920 unlocking problem | kiriazy | Motorola P2K (USB-Smart) | 6 | 08-21-2006 10:16 |
A920 Gprs problem | Egypt Unlocker | Motorola P2k | 1 | 12-18-2004 21:05 |
Next update can unlock A920 without problems! :-) | laxxe | Smart-Clip | 8 | 11-24-2004 21:14 |
A920 - unlock problem ;( | AndRe DCF-gsm | Smart-Clip | 15 | 11-22-2004 18:47 |
