02-05-2010, 17:38 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: Mullholand Intersection
Member: 159709 Status: Offline Sonork: +862150372500 Thanks Meter: 146 | Can't update smart adaptor firmware Warning: make sure you use power adapter! Smart Adaptor serial: 3355886xxx Boot version: 1.02 Firmware version: 0.00 Boot reason: Update request Smart Adaptor serial: 3355886xxx Boot version: 1.02 Firmware version: 0.00 Boot reason: Update request Smart adaptor warranty period: 07-Jul-2008 to 03-Jan-2009 (expired) u2l_init request... Access denied Update error Smart Adaptor serial: 3355886xxx Boot version: 1.02 Firmware version: 0.00 Boot reason: Update request Smart Adaptor serial: 3355886xxx Boot version: 1.02 Firmware version: 0.00 Boot reason: Update request Smart adaptor warranty period: 07-Jul-2008 to 03-Jan-2009 (expired) u2l_init request... Access denied Update error i have do all this procedure: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights 8. You should clear cache of your browser and restart the computer. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SM-tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" Please help me ASAP Last edited by VirtualMachine; 02-05-2010 at 17:42. Reason: Smart Adaptor serial |
02-05-2010, 19:54 | #2 (permalink) |
Member: 159709 Status: Offline Sonork: +862150372500 Thanks Meter: 146 | After instal new OS Smart-Clip update software 3.08 Warning: make sure you use power adapter! Reading clip info... Auto searching clip... Looking for clip on Smart Adaptor... OK Clip serial: 1854XXXXXX Firmware not found Auto searching clip... Looking for clip on Smart Adaptor... OK Clip serial: 1854XXXXXX Firmware not found login... denied European market Smart-Clip Clip warranty period: 05-Mar-2007 to 01-Sep-2007 (expired) EEPROM test successfull,reporting... OK Checking dongle... OK Smart-Clip dongle found, serial 98145XXXX Update denied, save log and contact support |
02-06-2010, 09:17 | #3 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Please check this link and send you 2 log files as mentioned there. ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com http://www.boot-loader.com Become a Boot-Loader v2.0 Fan Become a Smart-Clip Fan |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
02-06-2010, 14:40 | #4 (permalink) | |
Member: 159709 Status: Offline Sonork: +862150372500 Thanks Meter: 146 | Quote:
Can't update smart adaptor firmware | Uno_x | Smart-Clip | 10 | 02-25-2014 06:48 |
error when updating smart adaptor, any solution? | reyes_inco | Smart-Clip | 3 | 07-10-2008 07:47 |
Updating Smart-Adaptor Please Help GSMServer Team | mamo_mogon03 | Smart-Clip | 4 | 06-07-2008 18:48 |
i can't update smart clip | robinhood | Smart-Clip | 3 | 02-11-2006 15:03 |
Can't update smart-clip - urgent | whiffin | Smart-Clip | 7 | 01-26-2006 11:36 |
