06-05-2008, 17:09 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Philippines
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | Updating Smart-Adaptor Please Help GSMServer Team Warning: Make sure you use pwer adapter! Clip Serial:******** Firmaware version: 4.07 Login...OK Server firmware version: 4.07 Clip warranty period: **Aug 200*to ** feb 200* EEPROm test successful,reporting...OK Checking dongle...OK Smart-Clip dongle found,serial ******* Smart-clip doesn't need update USB adapter serial:****** Boot version: 1.00 Firmware verion: 1.01 Smart-adapter warranty period: 04-jun-2008 to 01-Dec-2008(180 more days) Sownloading U2l_initial....100% waiting device error Install driver for bootloader and try again I already follow the procedure on www.bootloader.com smart adapter update, but have this error appear. What should I do please advice me. Thanks in advance |
06-06-2008, 07:25 | #2 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mamo_mogon03, Please reinstall drivers for the Smart Adaptor. Detailed manual with the drivers can be found here. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
06-06-2008, 17:15 | #3 (permalink) |
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | I did follow instruction installing smart adapter driver but problem still the same sir. I reinstall the driver when it ask @ c:\Program Files\GsmServer\SmartMoto\drivers\ClipUSB\. it still ask for install drver for bootloader and try again. |
06-07-2008, 09:05 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,767 | Please send your log file from Smart Adaptor update along with the serial number to support[at]smart-clip.com. Also, please include the detailed description of all your steps and procedures that you have performed. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
06-07-2008, 18:48 | #5 (permalink) |
Member: 235905 Status: Offline Sonork: 100.1580742:mamomogon03 Thanks Meter: 145 | After three days of trials. Problem resolved. Here is my new logs few minutes ago. SmartClip update software 2.16 Warning: make sure you use power adapter! USB adapter serial: ********** Boot Version: 1.00 Firmware version: 1.01 Smart adaptor warranty period: 04-Jun-2008 to 01-Dec-2008(178 more days) downloading u2l_init...100% Waiting device driver error Install driver for bootloader and try again second try: USB adapter serial: ********** Boot Version: 1.00 Firmware version: 1.01 Smart adaptor warranty period: 04-Jun-2008 to 01-Dec-2008(178 more days) Sending RAMBoot... 100% Update error and another tries: and look my USb serial number and firmware version change USB adapter serial: 0 Boot Version: 1.00 Firmware version: 0.00 internal server error No need update, you have the last version And finally: USB adapter serial: ********** Boot Version: 1.00 Firmware version: 1.01 Smart adaptor warranty period: 04-Jun-2008 to 01-Dec-2008(178 more days) Reading new firmware version New Boot version 1.01 new firmware version: 1.04 Update completed successfully. At many tries I successfully update my smart adaptor. Problem solved! thank you to mr tinkertrain and to gsmserver for utmost support and endless help. Thank you sir! |
Can't update smart adaptor firmware | Uno_x | Smart-Clip | 10 | 02-25-2014 06:48 |
Can't update smart adaptor firmware | VirtualMachine | Smart-Clip | 3 | 02-06-2010 14:40 |
error when updating smart adaptor, any solution? | reyes_inco | Smart-Clip | 3 | 07-10-2008 07:47 |
my hwk not update and work please help saras team | aha_gsm | HWK | 7 | 11-05-2007 17:46 |
Problems updating my Smart-Clip please help me Smart-Clip Team | tito millo | Smart-Clip | 1 | 09-22-2007 10:22 |
