02-19-2009, 11:56 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 400705 Status: Offline Thanks Meter: 31 | afSupport, have a problem with w490 after smart tp |
02-19-2009, 12:16 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi... Error 9B is not the cause of no LCD backlight. Error 9B just means that the unlocking did not process correctly...so just repeat the prepare process once again...(with both TPs) To fix your LCD backlight issue...search this forum as there is detailed posts on how to fix . No LCD Backlight is Hardware problem caused by shield removal. Check the PCB ...especially where you removed the shield. Good Luck ,smokin |
02-19-2009, 12:37 | #3 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | If bootloader is 0C.50 and you have SmartTP ver.2 you can unlock using only TP A, if bl is 0C.A1 you have to use ALWAYS both TP A & B. Info applys to W490, W510, W5 and W6. |
The Following User Says Thank You to jepetu For This Useful Post: |
help me SmartMotov3.21Flashing w490 and Smart TP v2 | hungb | Smart-Clip | 1 | 04-22-2009 13:26 |
Unlock W490 without smart tp cable | irfan99 | Smart-Clip | 1 | 11-12-2008 08:42 |
dear mr odia im have big problem with hwk after instal new updeit ! | delchoni | HWK | 4 | 11-15-2007 16:33 |
V360 09.02 problem with bluetooth after unlock with TP | Mounir | Smart-Clip | 2 | 02-28-2007 09:25 |
problem with update my smart moto and clip have one picture plz help now | amira77 | Smart-Clip | 2 | 05-30-2006 11:05 |
