07-05-2006, 22:10 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: singapore Age: 55
Member: 173565 Status: Offline Thanks Meter: 71 | After unlocked V975 operator locked now phone locked? What have I miss out? |
07-06-2006, 08:01 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ mccm, To remove User code You can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. If that will not help, than You should make Repair PDS using TP method and after that Full flash. To reset security code You have to make Repair PDs and Full Flash the phone using TP method. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
07-06-2006, 23:58 | #3 (permalink) |
Member: 173565 Status: Offline Thanks Meter: 71 | Thanks for your reply,the security code changed too. So I have to do the PDS now. But could not get the flash files for it, can I backup the files from the phone,then flash back to it? |
07-07-2006, 08:12 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ mccm, After Repair PDS procedure You have to Full Flash the phone with *.smf file. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
07-13-2006, 09:38 | #6 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | You can buy an access through www.GSMserver.com Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
...:::5310 after reapir unlock or sd data now phone security test failed:::... | SHIJILFONOTLY | Universalbox | 3 | 12-03-2009 09:26 |
...:::5310 after reapir unlock or sd data now phone security test failed:::... | SHIJILFONOTLY | Nokia Base Band 5 ( BB-5 ) | 11 | 12-03-2009 07:39 |
N73 softbank after unlock contact operator service | probs | BB5KING for (BB5BOX) | 11 | 11-13-2008 11:06 |
Q105 wrong after now phone locked return for servicing | Sadabahaar | Trident/AGERE Platform | 0 | 02-21-2008 17:54 |
gx10 after unlock no operator | surfer2go | Sharp | 4 | 02-18-2005 19:34 |
