01-26-2007, 19:44 | #1 (permalink) |
Insane Poster Join Date: Jan 2007
Member: 425797 Status: Offline Thanks Meter: 0 | avoid to MEM MAP Blank i damage 2 sets v3i and v3r which recover after flash proccess. and i note my mistake that in first step where smart moto says remove battery and insert again and power on. at this step i also remove my data cable. Next when smart moto says disconnect cable and battery remove insert phone should be in black screen mode at this stage i got MEM MAP error when i insert battery phone always in boot mode. Please correct me if some thing wrong and if this is cause of this error please verify it. this will help many members. Thanks to all and smart clip team. BR |
01-26-2007, 23:34 | #5 (permalink) |
No Life Poster Join Date: Dec 2004 Location: all over the world Age: 46
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | NOTE: If there was any mistakes made during unlock process, and the handset is in "MEM_MAP Blank" mode, then "Prepare" process has to be repeated and the handset has to be flashed with reflash or full_flash file. At the stage 11, handset screen might display a "Critical error" message. Please, don’t be worried and strictly follow the instructions of SmartMoto. |
01-26-2007, 23:48 | #6 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: In QBits and X86/ASM code Age: 41
Member: 110715 Status: Offline Sonork: - Thanks Meter: 234 | Quote:
i know that.. thing what i dont know is why prepare procedure has too many errors.. | |
01-26-2007, 23:52 | #7 (permalink) |
Member: 101769 Status: Offline Sonork: 100.95669 Thanks Meter: 68 | 99% is a comm problems for fix this on prepare cycle you only have to repeat procedure no phone dead 1000000000% sure. br |
01-27-2007, 19:11 | #8 (permalink) |
Member: 425797 Status: Offline Thanks Meter: 0 | but once when you got this error you can not get back it to normal by repeating prepare cycle you need to flash it and think when you have no flash file in your system and like me other too many users has boot loader support problem can not get file at time... so specialy we need to proper solution. @wynasoft1 99% is a comm problems for fix this on prepare cycle you only have to repeat procedure no phone dead 1000000000% sure. please write down some words to fix this please clear it more. we all members need it. Thanks in advance |
02-03-2007, 11:20 | #11 (permalink) |
Insane Poster Join Date: Jun 2005 Age: 47
Member: 150369 Status: Offline Thanks Meter: 6 | I have the same problem with my V3i. I flash with new software from smart-clip support but this phone now not on anymore.Just light-up when i press power on. I try to repair PDS and full flash,same problem.Any one help me pleaseeeeee |
02-03-2007, 11:27 | #12 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ minhluon, what boot and firmware versions the phone originally had? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-03-2007, 11:38 | #13 (permalink) |
Member: 150369 Status: Offline Thanks Meter: 6 | i forgot to check before unlock,i do some v3i before no problem therefor i not check.But i did repair PDS V3i_479 and flash with V3i_R479_G_08.B5.10R_lp002E_full_flash.mfw but no use phone still dead |
02-03-2007, 11:44 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ minhluon, original firmware version was R479 or R47a? Try to make Repair PDS for v3i (R47a) and after that flash the handset with v3i_r47a_g_08.d8.a1r_lp0021_full_flash.mfw Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-03-2007, 14:34 | #15 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Bradford, West Yorkshire, UK
Member: 373231 Status: Offline Thanks Meter: 5 | Hi all... Let me help everyone here I have had this problem about 20 times now... So far I know how to repair phone without needing to flash and I have one or two simple steps for everyone to follow when preparing - this may help your future MEM MAP problems. Basically: When unlocking phone, do as told exactly, when it says "Remove and Insert Battery and power on Phone" then do so... then in the final stage - when it says, remove USB cable, remove battery, reinsert battery blah blah - well do this: Unplug USB cable, Remove Battery, wait 10 secs, insert battery, wait 2secs, then insert USB cable - then press power button for 1 sec. I always do this and not had one MEM MAP blank error since. - I noticed the cable can cause the fault due to the 5v+ going down USB. Now you know how to just about avoid this problem. Now to fix a dead phone with MEM MAP BLANK. Simple: When in final stage of preparing - if phone says "MEM MAP BLANK" then remove USB Cable, remove battery, wait for dialogue box to open asking to remove cable, battery blah blah, then get the phone board and put it in testpoint mode (short testpoint and attach battery) then hit ok in smart moto - should find phone and restore the patch that gets erased - then phone is working and unlocked. br, Danny. |
Moving Messages from phone mem to mem card | Umster | Nokia Base Band 5 ( BB-5 ) | 1 | 12-31-2007 10:08 |
Nokia N73 & pc suite (backup from phone mem to mem card) | Umster | Nokia Base Band 5 ( BB-5 ) | 0 | 10-08-2007 22:47 |
L6 Mem-map Blank After Flash | toptech | Ultima Box Light | 1 | 08-25-2007 11:14 |
L6 service mem-map | oakie42 | Smart-Clip | 5 | 05-22-2007 21:57 |
Transfer sms'es from phone memory to mem card | frankmehta | Nokia Multimedia | 0 | 03-17-2005 17:25 |
