11-07-2008, 14:22 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: sénégal
Member: 155963 Status: Offline Thanks Meter: 5 | Boot loader v3i i have a problem with v3i when i insert battery the phone is in boot loader 0a.30 ver R479_G_08.B4.34R i flash it with this version V3i_R479_G_08.B5.86R_lp0003_full_flash.mfw but same i have this Thanks to a l'aide de Mr. Christophe <[email protected]> for translation to Francais! SmartMoto 3.17 S-Card: xxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxx Europe, Remise a 0... OK Numéro de série du clip : xxxxxxx, version: 4.08, Remise a 0... OK Recherche du téléphone trouvé S Blank Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK Lecture de boot version du téléphone. 3.00 Lecture flash id... ST - M30L0R8000B0 Lecture flash id/2... ST - M30L0R8000T0, OK Groupe de téléphone: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 IMEI Hardware: 35xxxxxxxxxxxxxxx IMEI OTP status: locked Security area sauvegardée a "PDS for S Blank Neptune LTE2 35xxxxxxxxxxxxxx (25).mbk" Écriture de la section flash de 2 a 2... 100% (76 Kb/sec) Flash complet! Arrêt du téléphone... OK and the phone not power on and the boot is 3.00 i reflash with a boot file V3i_boot_A[1].3.0.smf and it come back to boot mode. Recherche du téléphone trouvé S Blank Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK Lecture de boot version du téléphone. 3.00 Lecture flash id... ST - M30L0R8000B0 Lecture flash id/2... ST - M30L0R8000T0, OK Groupe de téléphone: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 IMEI Hardware: 35xxxxxxxxxx IMEI OTP status: locked Security area sauvegardée a "PDS for S Blank Neptune LTE2 35xxxxxxxxxxx (26).mbk" Écriture de la section0 Effectué Flash complet! Arrêt du téléphone... OK help please!!!!!!!!! |
11-07-2008, 15:27 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ penda, Try to perform Repair PDS procedure and after that Full Falsh the set with the R479_G_08.B5.86R once again. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 11-08-2008 at 09:36. |
11-08-2008, 09:41 | #4 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Please explain, how did you connect your phone? Have you used TestPoint method or the phone was connected directly with just means of data cable? Also, do you have an idea what has initially happened to that particular handset, so it got the current state? Best Regards GSMServer team |
11-08-2008, 11:14 | #5 (permalink) |
Member: 155963 Status: Offline Thanks Meter: 5 | first i have connected it directly with cable and prepare mode boot is 0A.30 after i used tespoint method but no result nothing happened with phone he removed battery and put it back and the phone come in boot mode. |
11-08-2008, 11:57 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try performing Prepare, Repair PDS and full flash with V3i_R479_G_08.B5.86R_lp0003_full_flash.mfw again. In case of any error, please show us the log without serials. Best Regards GSMServer team |
11-08-2008, 14:12 | #7 (permalink) |
Member: 155963 Status: Offline Thanks Meter: 5 | Recherche du téléphone trouvé S Flash Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK Numéro de série du clip : xxxxxxxxxx, version: 4.08, Remise a 0... OK Recherche du téléphone trouvé S Flash Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK Lecture de boot version du téléphone. A.30 Envoie du Boot OK effacer la memoire flash OK Sending firmware OK Recherche du téléphone trouvé S Blank Neptune LTE2 Passage en mode Flash... OK Lecture de boot version du téléphone. 3.00 Lecture flash id... ST - M30L0R8000B0 Lecture flash id/2... ST - M30L0R8000T0, OK Groupe de téléphone: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 IMEI Hardware: 3xxxxxxxxxxxxxxxx IMEI OTP status: locked Security area sauvegardée a "PDS for S Blank Neptune LTE2 35xxxxxxxxxxxxxx (34).mbk" Déblocage du téléphone OK To get phone to work, you should write flash into the phone Demande de l'identifiant ... OK Écriture de la section flash de 2 a 2... 100% (46 Kb/sec) Redémarrage du téléphone. OK Recherche du téléphone trouvé S Blank Neptune LTE2 Passage en mode Flash... OK IMEI OTP status: locked demande de réparation PDS... OK Executation de la réparation PDS... OK Écriture de la section flash de 1 a 1... 100% (15.8 Kb/sec) Veuillez écrire dans le telephone un fichier correspondant full_flash pour terminer la réparation Écriture de la section flash de 2 a 2... 100% (76 Kb/sec) Flash complet! Arrêt du téléphone... OK not power and boot still on 3.00 |
11-10-2008, 09:28 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ penda, Please explain in more details what do you mean by the words "not power and boot still on 3.00"? When you connect the phone to SmartMoto and read phone info, how does it get detected? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-11-2008, 18:00 | #9 (permalink) |
Member: 155963 Status: Offline Thanks Meter: 5 | i have this "Recherche du téléphone trouvé S Flash Neptune LTE2, Interface test Interface non trouvé Passage en mode Flash... OK" and i can go directly to writh flash without preparing you understand? |
11-12-2008, 09:51 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ penda, The set get detected by the SmartMoto as "S Flash..." or "S Blank..."? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-13-2008, 09:09 | #11 (permalink) | |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Quote:
Best Regards GSMServer team | |
How to Change Boot Loader V3i | Qaisar Mahmood | Smart-Clip | 1 | 11-04-2008 08:53 |
I can not unlock Motorola V3 New Boot Loader and V3i Boot Loader:0A.30 with S_card!! | GsmOrient | Smart-Clip | 2 | 01-26-2007 14:09 |
V3i With Boot Loader 0A.52 | phanthom2o4o | Smart-Clip | 1 | 12-23-2006 10:18 |
v3i boot loader 04.30. afterflash no power on | mr ngoma | Motorola P2k | 0 | 08-06-2006 12:22 |
V3i all boot loader direct unlock no test points | ttsunlock | Main Sales Section | 0 | 02-09-2006 16:54 |
