11-30-2006, 14:08 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Live in your Heart
Member: 71045 Status: Offline Thanks Meter: 19 | C975 bootloader 6.3.6 version 801 what is wrong any idea what is wrong with this mobile it need to unlock (network lock) log detail is given below :- Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... 0x006C-0x00B1 (x2) Phone group: A835,A845,A920,A925 Reading OTP... error B8 Warning: OTP read failed Incomplete chip identification, restore & write functions unavailable power on like normal mobile thanks & regards Zafar Janjua |
11-30-2006, 14:18 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ .::Zafar Communication::., Reading flash id... 0x006C-0x00B1 (x2) this string shows that flash chip can't be read properly. In such sitautions there are 2 main reasons for this error. First Flash chip damaged, second TP wasn't made correctly. If the phone powers on normally and work normally, most probably that the problem is in TP. Try to unlock the handset again and make sure that TP done correctly. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-30-2006, 16:54 | #3 (permalink) |
Blocked Join Date: Jan 2004 Location: PAKISTAN Age: 52
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Hi, I was unlocking c975 with Firmware R245_U_82.21.80I and with bootloader 6.3.6, something went wrong ..... Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354991000823BD7 WARNING! Your phone may not power on after downgrading firmware version. It is possible that you meet problem with phone unlocking. Security area saved to "S Blank Rainbow POG 354991000823BD7.pds" Unlocking phone... error A4 now the phone is dead not doing pds repair, flashing or restoring backup. Br Xtreme |
12-01-2006, 09:15 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ xtreme, If you have made backup, flash the phone with it. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-01-2006, 15:04 | #6 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | @zafar Bad TP mate U Damaged its Location Both IC,s Wont be able to Make Connection with Each other..... Try Repair it..Apply some Flux Rehot Will Improve its Connection GoodLuck |
12-01-2006, 17:00 | #7 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | i had this problem Quote:
12-03-2006, 03:33 | #8 (permalink) |
No Life Poster Join Date: Jan 2005 Location: EVERYWHERE U GO Age: 46
Member: 106026 Status: Offline Sonork: 100.77890 Thanks Meter: 127 | unlock dis many models of dis fones wout aany problem....u get dis error why u cut shields ...cos c975 is touch sensitive |
12-03-2006, 06:22 | #9 (permalink) |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | i don't think zafar phone will be alive again. but xtreme have 99% chances to get it back alive. with fully batt and making a good TP method again. Coz zafar phone is showing wrong phone group but xtreme is lucky so far. @ Xtreme try both method one by one with 101% Fully charge BATT. Do TP and UNLOCK VIA TP" if failed Do TP and Downgrade Bootloader manually. lets c result. BR. |
12-05-2006, 09:47 | #10 (permalink) |
Junior Member Join Date: May 2006
Member: 269390 Status: Offline Thanks Meter: 1 | phone on to dracek boot loader on plz help me plz help me C975 bootloader 6.3.6 version 80I testpoint Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354991001035205 Security area saved to "S Blank Rainbow POG 354991001035205 (2).pds" Unlocking phone... error 9B |
12-05-2006, 10:01 | #11 (permalink) |
Member: 269390 Status: Offline Thanks Meter: 1 | phone on to dracek boot loader on plz help me plz help me C975 bootloader 6.3.6 version 80I Used testpoint Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354991001035205 Security area saved to "S Blank Rainbow POG 354991001035205 (2).pds" Unlocking phone... error 9B |
12-05-2006, 10:19 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ akhil123, Please make sure that you use standard, not force boot, cable. And try once more. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-06-2006, 16:16 | #13 (permalink) |
Member: 48518 Status: Offline Sonork: 100.113013 Thanks Meter: 127 | Thanks for all your replies, I have tried to repair pds and also tried to flash bootloader manually it gives following error, and of course i am using variable power supply. SmartMoto 1.22 Clip serial: XXXXXXXXX, version: 2.26, initializing... OK Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Micron-MT28F1284W18BET (x2) Phone group: C975,C980,V980 Hardware IMEI: 354991000823BD7 ----------------> why imei is like this??? WARNING! Your phone may not power on after downgrading firmware version. It is possible that you meet problem with phone unlocking. Security area saved to "S Blank Rainbow POG 354991000823BD7 (19).pds" Login request... OK Writing section0 8000/10000... 50% 44.7 Kb/sec sector erase error Extended sector erase error code is 8000B0 Br Xtreme |
12-07-2006, 06:53 | #14 (permalink) | ||
Member: 128918 Status: Offline Thanks Meter: 282 | Both u guys have to play alot with this thing. U will see everytime it will show diffrent log. But don't giveup untill u success. heres the example. even once S-moto show me following Message in v3x case. here u can see. Now See the Log 100% Diffrent with each other. But at last it was Cool. Be sure everytime i made TP. SmartMoto 1.23 Clip serial: 39xxxxxxxx, version: 2.26, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R252211LD_U_85.97.F1P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R252211LD_U_85.97.F1P Reading info OK Clip serial: 39xxxxxxxx, version: 2.26, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Searching for phone... no phone found Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... clip communication failed Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R252211LD_U_85.97.F1P Reading info OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 358003003239508 Security area saved to "S Blank Rainbow POG 358003003239508.pds" Unlocking phone... OK Quote:
Goodluck Guys. | ||
03-09-2007, 13:10 | #15 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Malappuram. INDIA
Member: 412813 Status: Offline Sonork: 100.1594692 Thanks Meter: 353 | 6.3.6 R245_u_82.21.80I unlocking solution Quote:
You can unlock it by following procedure 1. Repair pds 2. flash with fullflash file checked 100% ok M A Sabah Britco & Bridco Karol Bagh New Delhi | |
HOW TO UNLOCK Motorola C975 boot loader 0.6.3.6 sw ver.R245_U_82.21.801 | joan6668 | Motorola P2k | 8 | 02-25-2007 16:24 |
Motorola C975 boot loader 0.6.3.6 sw ver.R245_U_82.21.801 unlocking | .::Munazzam::. | Motorola P2k | 6 | 01-20-2007 17:53 |
C975 Boot Loader 0.6.3.6 SW Version :R245_U_82.21.91I is still not supported | irfan99 | Smart-Clip | 0 | 12-04-2006 18:08 |
C975 Bootloader 6.3.6 | karamusa | Smart-Clip | 2 | 10-15-2005 11:24 |
c975 bootloader 6.3.6 unlocking problem | Moosani | Smart-Clip | 1 | 09-26-2005 19:05 |
