05-05-2006, 16:32 | #1 (permalink) |
Freak Poster Join Date: Sep 2003
Member: 38138 Status: Offline Thanks Meter: 4 | Dead V3 after flashing, really need help I have attempted to flash a V3 phone for the first time using :R374_G_0E.40.79R_lp0034_full_flash.smf 32.05 Mb 30 Dec 2005 2197 so as to debrand and add languages. The handset after flashing is dead . When trying to search for the handset i get the message: when i do the 'search' to connect the phone it comes up with "found S Flash Neptune LTE, getting test interface... inteface not found" then "Switching to flash mode... OK" 've tried to write the flash again and it's coming up with "Incomplete chip identification, restore and write functions unavailable" The same when trying PDS repair. Would be really grateful for some help, Regards kamil |
05-05-2006, 16:37 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello soudies, Please post a log file of unlock process, it would spread some light on your problem. P.S. Do not forget to hide your serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2006, 16:46 | #3 (permalink) |
Member: 38138 Status: Offline Thanks Meter: 4 | I am afraid I did not keep a logfile-the info that i originally pasted is the only info that i have a record of. Is there somewhere in the Smartmoto file that records it and files it from which i can extract the info? |
05-05-2006, 16:54 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ soudies, Try To make Reapir Pds again, save log file and post it here. Don't forget to hide serial number! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-05-2006, 17:05 | #6 (permalink) |
Member: 38138 Status: Offline Thanks Meter: 4 | Hope this is of use: SmartMoto 1.18 Clip serial: xxxxxx, version: 2.23, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: xxxxxxxxxxxxxxxxx Current phone does not correspond model selection Regards kamil |
05-06-2006, 09:18 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ soudies, Please update your Smart-Clip and Smart-Moto. Check the mainboard of the phone most of all flash chip is damaged or haven't read properly. Please check it! Thank You! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
dead 8180 after flash by 8138 HELP!!! | mutualmobile | LG | 9 | 10-21-2005 05:43 |
SE S710 dead after flash I need help...! | joallo | HWK | 0 | 09-26-2005 06:51 |
Dead C650 After reflash I Need Help ! | leviatan21 | Motorola P2k | 1 | 02-18-2005 18:21 |
Display BLANK after Flashing SL45!!! NEED HELP, PLSS!! | nickfg | x1x to x45/x50 | 8 | 01-10-2003 02:07 |
