Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 12-08-2006, 11:08   #1 (permalink)
Member: 68795
E1070 not unlocked after tespoint unlock ??
Today I unlocked an E1070 via testpoint, smartmoto says unlocked ok but phone still asking for subsidy password ????
Anyone know whats wrong ?
Old 12-08-2006, 11:12   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 636
@ Itsbroke,
please tell us what Smart-Clip and SmartMoto versions you use.
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 12-08-2006, 11:57   #3 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
Hi,
There are new version of E1070, So far i know only on the network 3. It seems this version is like the C975 91i.... version which is still locked after unlock.
We can try to flash it with latest firmware then unlock, But pls firstly read flash and send it to support.
B.R
Old 12-08-2006, 13:03   #4 (permalink)
Member: 68795
Versions
I am using smartmoto v2.0 and fgirmware version 3.0
Old 12-08-2006, 13:26   #5 (permalink)
Member: 229997
Thanks Meter: 636
@ Itsbroke,
Please show log file, don't forget to hide seial number.
Also,please specify what boot and firmware versions the phone has and tell us what OS you are using.
Thank You!
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 12-08-2006, 17:01   #6 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
e1070
boot loader
0.6.8.1
sw version
R252211LD_U_.97.F11P
Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.10
Reading bus width... OK
Reading flash id... Intel-28F256L18B (x2)
Phone group: E770,E1000,E1070, V3x,V975,V1050
Hardware IMEI: xxxxxxxxxxxxxx
Security area saved to "S Blank Rainbow POG xxxxxxxxxxxx(1).pds"
Unlocking phone... OK
Turning phone off... OK
BUT THE PHONE STILL LOCKED
Searching for phone... found Motorola Phone (E1070), getting test interface... OK
Model E1070
Firmware R252211LD_U_85.97.F11P
Reading info OK
as we know that we had no solution for C975 with sw ending with 91i so here goes another model in the same list
REASON FOR POSTING IS TO HELP OTHERS TO WAIST THEIRE TIME FOR DRILLING AND UNLOCKING ETC
Old 12-08-2006, 17:45   #7 (permalink)
Member: 68795
Need back up flash of 3 E1070
Hi I have really screwed this up !! I tried to unlock an E1070 on 3 UK, it said done OK but it wasn't unlocked, tried to do PDS repair, then flash full flash from support but now wont power on just flash keypad, but will go into boot mode with *# power pressed, I need a full backup of this handset as the one in support doesn't work I have seen posts from others who have reflashed with back up from an identical handset then restored the original security area and handset alive again, I just desperately need the back up flash file for this
Old 12-08-2006, 23:43   #8 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
Well like i posted above it has a very similar patched firmware like on the c975 91... version.
Try to flash the fone using upper version or the same.
B.R
Old 12-09-2006, 01:16   #9 (permalink)
chowdary's Avatar
Member: 91102
Thanks Meter: 34
hi
u can't flash backup made by one smart-clip with another smart-clip
c if u can find this file in support area
br
Old 12-09-2006, 10:57   #10 (permalink)
GSM_Support's Avatar
Member: 121052
Sonork: 100.107126
Thanks Meter: 80,766
That version can be unlocked with the latest version of SmartMoto (with use of Smart-Clip and S-Card), which has a "firmware version check" process implemented.
While connecting the handset to SmartMoto and trying to unlock, if the software does not alert you: "In case of downgrading the firmware version the handset might not turn ON", then flash it with the lower full_flash version and perform "Unlock via TestPoint".
Best Regards
GSMServer team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 12-09-2006, 12:31   #11 (permalink)
damabib's Avatar
Member: 106026
Sonork: 100.77890
Thanks Meter: 127
ok with scards good job sc team
Old 03-22-2007, 13:54   #12 (permalink)
Member: 144041
strange problem motorola E1070
i have i strange problem motorola E1070
i did same ,I unlocked an E1070 via testpoint, ubl says unlocked ok but phone still asking for subsidy password ????
i pressed repair bt
and i get terminal blocked
Old 03-22-2007, 14:05   #13 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
i pressed repair bt
Yeah I know what's wrong! Your in the wrong section!
WBR
MFC
Old 03-23-2007, 16:26   #14 (permalink)
Member: 144041
WBR
MFC
if you know what its wrong why you dont just give answer , just here we are learning and sharing information ok?
thanx for any one guid and shar information
NO ONE CAN DO EVERY THINGS BUT ANY ONE CAN DO SOME THING .
Old 03-23-2007, 18:58   #15 (permalink)
MFC
MFC's Avatar
Member: 83741
Sonork: 100.1624702
Thanks Meter: 88
Yes you can do something! Like posting in the correct section.
WBR
MFC
K1/S not unlock after successful UNLOCK zakiyyboss Smart-Clip 1 01-20-2009 14:24
E65 loudspeaker not working after TP unlock donish Nokia Hardware & Hardware Repair 3 03-04-2008 22:20
T610 not working after bad unlock Delsole Sony Ericsson 1 02-17-2006 09:08
Modem not working after e616v unlock pucuchu NEC 0 03-25-2005 06:40
M55 not charging after testpoint unlock DMD E-Gold Based Phones 1 12-09-2004 11:25
Page generated in 0.27374 seconds with 9 queries
